Old 11-28-2018, 01:06 PM   #1
cal scott
Rookie
cal scott's Avatar
Motorcycles: V-Strom DL650AL3
When to change a chain
This may be a topic previously addressed ad nauseum, however, my efforts to search the site haven't come up with any answers. This may also be much like oil and tires where everyone has an opinion but there is no common consensus. Despite these shortcomings, I will cautiously ask anyway .
How do you determine that an O/X ring chain is at the end of its life and needs to be changed? Bike manual states that it should be changed once it has "stretched" a predetermined amount. Other sources state that stretch generally doesn't matter and the state of the links is more the determinant - frozen links and general rusting indicate loss of the sealed chain lubricant. Collective thoughts of the group?
While I am at it, just wondering what the thinking is on changing sprockets...?
- Change both the front and the back every time you change the chain
- Change the front every time but perhaps not the back as that wears more slowly
- They don't need changing every time; depends on wear so assess before making a decision
To those dead souls inching along the freeways in their metal coffins,...
..we show them that the human spirit is still alive.
-- Point Break
cal scott is offline   Reply With Quote
Old 11-28-2018, 01:15 PM   #2
Junkie
re-tarded
Junkie's Avatar
Contributor + 3%
if the links are sticking, it's done
if the chain is stretching quickly, it's done
surface rust on the outside isn't all that important
I change both sprockets every time I change the chain
Old 11-28-2018, 01:27 PM   #3
mototireguy
Moto Tire Veteran
mototireguy's Avatar
Valgar beer donor
Contributor +
Lift rear of bike or put on center stand.
Spin the wheel.
Do any of the chain links have any visible kinks or does the slack get tight/loose as the wheel spins?
Another check is to grip the chain with 2 hands and flex it side-to-side. There should be zero or very minimal side-to-side play.
And when changing the chain you typically match the new chain with new front/rear sprockets.
mototireguy is offline   Reply With Quote
Old 11-28-2018, 02:31 PM   #4
dravnx
dravnx's Avatar
AMA #3018349
Contributor +++++++
Barf Roadside Angel
Motorcycles: '12 DL650A '15 FJR1300A
Also look for the brown dust of death. It will look like rust but is actually metal dust that has rusted. It's a sign of parts that are no longer lubricated and are eating themselves. Usually you'll see it covering 2-4 links in a row.
bike X miles=smiles
smiles ÷ bike=miles
miles ÷ smiles=bike.
It's simple math.
dravnx is offline   Reply With Quote
Old 11-28-2018, 02:55 PM   #5
Biga
Near Miss Racing #96
Biga's Avatar
Motorcycles: 250 Ninja "A" R3 600 GSXR TS 185 150 Scooter 97cc D. Bug
Whatever you do don't let it get like this one
CMRA# 672
Biga is offline   Reply With Quote
Old 11-28-2018, 04:13 PM   #6
m0t0_ryder
RYD!
m0t0_ryder's Avatar
Contributor +
Motorcycles: Big to small. I like 'em all. 950ADVS-450EXC-R100GS-TW200-YW50P-XR600-Z1-ST90-model165Hummer
Attachment 515286
What....
It's still got half it's teeth... sort of.
A gooD VoyagE Needs The Unexpected RoutE!
It didn’t look that far on the map.
Two wrongs don't make a right but three lefts do!
m0t0_ryder is offline   Reply With Quote
Old 11-28-2018, 04:30 PM   #7
Escape pod
Capable
Escape pod's Avatar
Motorcycles: Dirt Street
New chain on new sprockets, @ the back of the rear sprocket pull the chain away/ it lifts off the sprocket a little, a worn (drive-train) the chain lifts from the sprocket a lot.
Regina gold gives the best service
Escape pod is offline   Reply With Quote
Old 11-28-2018, 05:10 PM   #8
HadesOmega
HadesOmega's Avatar
Barfie Winner 2017
Motorcycles: Empulse TT, ZR7, DR650, KLR650, 750 Turbo, Warrior 350, KLX140L
If the chain stretches to the point the adjusters can no longer keep the chain slack in spec. When a chain is ready to go you will notice it will suddenly start stretching. You'll have to adjust it more frequently all of a sudden.
Also in your service manual it will tell you how to inspect the chain stretch. Usually it is tightening the chain so it is taut or hanging a weight on it and measuring the distance of a certain number of pins. If it is no in spec the chain is done.
Also if you if you chain seems to be stretching inspect your sprocket first it might be worn out. The front one wears out faster than the rear.
I just rode LAB2V on a chain that looked like shit but was still tight inspec but missing o-rings and some of the links are kinking. I punished that chain through 500+ miles of desert terrain and it didn't stretch at all. Modern or good quality chains can take A LOT of abuse. just clean and lube them and they'll last a while.
HadesOmega is offline   Reply With Quote
Old 11-28-2018, 06:24 PM   #9
ichabodnt650
FZ-07
ichabodnt650's Avatar
Motorcycles: FZ-07, YW125
25,000 miles if well maintained; sooner if not
ichabodnt650 is offline   Reply With Quote
Old 11-28-2018, 06:36 PM   #10
Aware
Aware's Avatar
Motorcycles: Honda
Random number generator?
Aware is offline   Reply With Quote
Old 11-28-2018, 07:50 PM   #11
kuksul08
Suh Dude
kuksul08's Avatar
Motorcycles: Whee!
There is actually a measurement that tells you plain and simple when it's time to replace it. You measure a certain number of links and if it's long than that, it's due for replacement because the pins have worn passed the acceptable tolerance.
I just replace them when the sprockets start showing wear, or if the links start getting rough.
Also, the 'red dust of death' is an obvious sign the chain is toast. You will see this red/brown powder all over some people's bikes. Once the dust happens, it is ruined.
kuksul08 is offline   Reply With Quote
Old 11-28-2018, 08:01 PM   #12
kuksul08
Suh Dude
kuksul08's Avatar
Motorcycles: Whee!
That's funny we both call it the brown dust of death. where did you hear that?
Old 11-29-2018, 08:08 AM   #13
ichabodnt650
FZ-07
Your front sprocket will exhibit 3x more wear than your rear, but you can't see your front as easily (Vstrom has 47 tooth ÷ 15 tooth = 3.13 times more wear to the front teeth)
I've replaced chains ranging from 20,000 ~ 35,000 of use, depending on how abused they have been. 25K is a comfortable interval for me personally.
Old 11-29-2018, 08:17 AM   #14
dravnx
dravnx's Avatar
AMA #3018349
Contributor +++++++
Barf Roadside Angel
Meant brown.
bike X miles=smiles
smiles ÷ bike=miles
It's simple math.
Old 11-29-2018, 12:02 PM   #15
Busy Little Shop
Man behaving bikely...
Busy Little Shop's Avatar
Motorcycles: Honda RC45 RC30
Mileage is a poor standard for wear because of so many variables...
A more accurate standard of chain wear is after the 3rd adjustment because
that is undeniable evidence that the factory installed grease is beginning to
fail to lube the critical pin roller junction hidden behind the X ring... the
length of the chain is growing because of this metal to metal wear... We can
not call a chain serviceable that is grinding on metal...
This is what we don't see behind the X rings... metal to metal wear
every time we adjust the chain that eats into our engine's available
HP... a new pin measures 206.5 and wears down to 205.5 at the 8K mile
mark... looks good to the naked eye but multiply that 1 thousand of an
inch times 108 links and you have 108 thousands of an inch wear or
about the range of the green marks provided by Honda's wear gauge...
202.8 show the very visible wear at the 12K mile mark... the pins are
turning red from extreme heat of grinding dry metal... a chain in this
condition may consume up to 6 to 8% of our RWHP... not to mention it
may snap into and cause case damage...
Some manufactures provided a handy guide to monitor chain wear... stay with
in the green and you'll be looking for a new chain and sprockets at the 8 to
10K mile mark...
What we are lubing are external roller and between the roller and the
sprockets (red area in my drawing)... we are not lubing the X rings
nor behind the X rings so any oil applied in that effort is a waste
and will only fling off...
Have a wheelie NICE day...
Lean & Mean it in every corner of your life...
If it wasn't for us the fast lane would rust...
V4'S are music to the seat of my pants...
1952 De Havilland Chipmunk...
https://www.youtube.com/user/BusyLittleShop/feed
http://s1036.photobucket.com/user/Bu...?sort=3&page=1
http://www.flickr.com/photos/55532474@N00/?saved=1
http://www.flickr.com/photos/10503451@N07/
Busy Little Shop is offline   Reply With Quote
