Old 12-26-2018, 08:37 AM   #1
SomeDudeOnline
Newbie
Motorcycles: Ninja EX650 FZ6
Question about 09 FZ6 Steering
Hey Guys,
This might belong in the Review section but I'm not sure so.. Kitchen Sink. Anyway, I just bought an FZ6 with 10 year old balding tires, everything else is great though. I did the test ride in the rain (never again, holy crap that was scary with those tires) and noticed the steering was a little weird but chalked it up to my limited experience with bikes (mostly just ridden my 650 ninja for the last 2 years) and the rain. However, now that it's dry and I've swapped out the rear (going to swap the front later today), it's still weird.
My buddy who's been riding for a long time had a chance to ride it and said the same thing. It's like it steers itself at low speeds. I'm sort of hoping that this will be resolved by changing the front tire but braking hard with the front doesn't produce any undesired results so I doubt the front tire is so slippery that it's causing this issue. Is there anyone out there who's had an FZ6 (not FZ6R) that can comment on what I'm describing? Is this normal for some bikes? If so, do you get used to it pretty quick? Will it still lean/turn like any other bike at higher speeds
Thanks,
SomeDudeOnline
SomeDudeOnline is offline   Reply With Quote
Old 12-26-2018, 08:46 AM   #2
Junkie
re-tarded
Junkie's Avatar
Contributor + 3%
I'd have put this in garage
a squared off or V'd off tire can certainly produce unusual handling characteristics
Old 12-26-2018, 08:52 AM   #3
CoorsLight
CoorsLight's Avatar
Contributor
Motorcycles: smell good
First check tire pressure and the head bearings. Then ask a mod to put this in garage.
CoorsLight is online now   Reply With Quote
Old 12-26-2018, 08:55 AM   #4
Map8
Don't H8
Map8's Avatar
BARF Moderator - BARF Sponsor
Barfie Winner 2017
Contributor + + +
Motorcycles: 2017 Df3, YZ250F/SM (parting out), DRZ400SM, KTM 450SMR, CRF230/sm
Moved to The Garage
Only stickers increase horsepower. Duh. -mikhail
“Valentino is just a super down-to-earth, right on dude,” -Brad Baker
BARF Terms of Service
Map8 is offline   Reply With Quote
Old 12-26-2018, 09:11 AM   #5
Maddevill
KNGKAW
Maddevill's Avatar
AMA #: 542337
Motorcycles: ZX14,GS750E, RM250
If you still have the worn front tire on I bet that is the problem. Fronts often wear into a point, causing the bike to fall in to turns. Put a fresh front on and get back to us.
Mad
Old 12-26-2018, 09:26 AM   #6
SomeDudeOnline
Newbie
Thanks to all who have already responded and to the mod for moving the post. The front tire is surprisingly rounded considering the rear was squared off. The tire is a bit low but as I understand it, that should help with this issue more than it would hurt right? I'll have my buddy help me check the head bearings later today and let you know if swapping out the tire makes a difference but if a hard tire wouldn't cause this weirdness, I'm not very confident the tire is the problem.
Old 12-26-2018, 10:04 AM   #7
augustiron
2fast 2live 2young 2die
augustiron's Avatar
Motorcycles: All of them eventually.
Are the top of the fork tubes sticking up above the top triple clamp? If so, how far?
augustiron is offline   Reply With Quote
Old 12-26-2018, 10:06 AM   #8
89fj
late braking
89fj's Avatar
Contributor +
Motorcycles: yamaha FJ-09 S1000RR
Mad
like he said
"old balding tires"......dead give away
89fj is offline   Reply With Quote
Old 12-26-2018, 10:34 AM   #9
SomeDudeOnline
Newbie
I don't believe so but will check later.
Originally Posted by 89fj View Post
I hope that's all it is. Am I wrong in thinking that braking hard with the front should cause slipping if the tire were bad enough to cause this weird steering issue?
Last edited by SomeDudeOnline; 12-26-2018 at 10:35 AM.. Reason: cleaning up format
Old 12-26-2018, 10:57 AM   #10
Junkie
re-tarded
Junkie's Avatar
Contributor + 3%
Yes, you're wrong.
An oddly worn tire can still have plenty of traction to lift the rear
Old 12-26-2018, 11:03 AM   #11
SomeDudeOnline
Newbie
Originally Posted by Junkie View Post
Yes, you're wrong.
Cool, well I'll keep you posted
Old 12-26-2018, 11:26 AM   #12
ST Guy
ST Guy's Avatar
I would pay zero attention to any handling quirks until BOTH ends have new rubber.
Old 12-26-2018, 01:29 PM   #13
GPzPop
Ask me about my B-1-D
GPzPop's Avatar
AMA #3295113
Contributor ++ 2%
Motorcycles: zzr & xsr
worn steering stem bearings feel like there are little notches or detents as you turn the handlebars back and forth. both while stopped and when in motion
Rust is my thread locking agent
1 Thessalonians 5:8 "But since we belong to the day, let us be self-controlled, putting on faith and love as a breastplate, and the hope of salvation as a helmet."
GPzPop is offline   Reply With Quote
Old 12-26-2018, 01:30 PM   #14
afm199
afm199's Avatar
Mod Alumni
Founding Member
Top Percent Poster
this. Either tires or bearings.
Old 12-26-2018, 02:16 PM   #15
bobl
Contributor
Motorcycles: ZX6 Kawasaki
Originally Posted by st guy View Post
i would pay zero attention to any handling quirks until both ends have new rubber.
this!
bobl is offline   Reply With Quote
