Net-Moto :: Community :: Racing :: :: Racing Videos | Sponsor :: Contact |
Forums
Features
Trackdays
Moto Crash Incidents
Race Team
CMSP Training
Sponsors
Donate
Terms of Service
Home UserCP Register Calendar Members FAQ Search |
#1 |
Newbie
Motorcycles: Triumph
Plastic button/valve at bottom of brake reservoir - What does it do?
Hello everybody,
I just wanted to flush the front brake on a new to me 2018 BMW G310R. Upon opening the reservoir, I discovered a white plastic button/valve. I've never seen something like this before, I'd assume it regulates the brake fluid flow towards the cylinder. As you can see, it is surrounded by a spring-style ring and it came out of the housing at the bottom of the reservoir. I wonder if a) anyone knows its purpose/has seen it before b) can tell me which side is up/down ( it's asymmetrical ) and c) if there is any trick or tools required for inserting it back into the housing. Thank you so much, Chris ![]() ![]() Last edited by _Chris_; 01-06-2019 at 09:31 PM.. |
#2 |
I believe it's simply a cover or cap over the intake and compensating ports. During use, brake fluid can shoot out of the ports with a fair amount of force which has the possibility of introducing air into the fluid. By keeping any turbulence below the air at the top of the resevoir, the fluid stays air free.
I may be wrong.
It's not the answer that enlightens, but the question. - Eugene Ionesco Let us not pray to be sheltered from dangers but to be fearless when facing them. - Rabindranath Tagore A mind all logic is like a knife all blade. It makes the hand bleed that uses it. - Rabindranath Tagore |
#3 | |
Suh Dude
Motorcycles: Whee!
#4 |
Yes, another purpose.
#5 |
- Kawasaki Fanatic -
Founding Member
From the heart
Motorcycles: ZRX1200
or keeping you from squirting yourself in the eye...
Enjoy the ride! |
#6 |
When cleaning out the reservoir, it's always a good idea to pop the cap/cover off and make sure it's clean underneath. (As you have done, OP.)
#7 |
Newbie
Thank you everybody for the feedback.
For future references, there is only way how you can insert it ( round side up ), here is the picture: ![]() |
#8 |
AMA #3018349
Contributor +++++++
Barf Roadside Angel
Motorcycles: '12 DL650A
'15
FJR1300A
Why are you doing a flush on an almost new bike?
bike X miles=smiles smiles ÷ bike=miles miles ÷ smiles=bike. It's simple math. https://www.directavionics.com/ |
Thread Tools | |
Display Modes | |
