Old 01-07-2019, 02:48 PM   #1
ab_rider
Newbie
Motorcycles: 2006 Suzuki V-Strom 650
V-Strom won't roll
Intermittently, my 2006 Suzuki V-Strom DL650 won't roll even in neutral. Sometimes the problem goes away. Other times, I almost can't roll the bike forward or backward. Could this be a problem with the clutch? I can't seem to figure it out.
ab_rider is offline   Reply With Quote
Old 01-07-2019, 03:11 PM   #2
Junkie
re-tarded
Junkie's Avatar
Contributor + 3%
you're sure it's in neutral?
it's the rear tire keeping it from rolling?
if it's really in neutral, the clutch isn't the problem
Old 01-07-2019, 03:22 PM   #3
ST Guy
ST Guy's Avatar
Likely nothing related to the clutch.
Next time it happens, try pulling in the clutch and see if it will roll. There may be extra drag, though. If you can roll it with the lever pulled all the way, then the bike is likely still in gear.
Or, next time it happens, simply fiddle with the shift lever, putting the bike in 1st and then 2nd and then finding neutral again. If that fixes it, the transmission is still in gear and it might be a problem or it might simply be you're not hitting neutral when you think you are.
Or, it could be a problem with the shift linkage hanging up. Is it clean and does it move freely?
Old 01-07-2019, 03:40 PM   #4
mototireguy
Moto Tire Veteran
mototireguy's Avatar
Valgar beer donor
Contributor +
Aftermarket Chinese bunk brake lever in use?
Stock brake levers sticking?
Possible bark buster lever guards interfering?
mototireguy is offline   Reply With Quote
Old 01-07-2019, 04:06 PM   #5
HadesOmega
HadesOmega's Avatar
Barfie Winner 2017
Motorcycles: Empulse TT, ZR7, DR650, KLR650, 750 Turbo, Warrior 350, KLX140L
It could be sticking brake pads. This can sometimes be intermittent. Inspect the guide pin boots and grease for tears or contamination.
HadesOmega is online now   Reply With Quote
Old 01-07-2019, 04:34 PM   #6
Tom G
"The Deer Hunter"
Tom G's Avatar
Motorcycles: BMW R1200GSA
I recently found a drywall screw in my rear tire, flat. Bike would hardly move. Fixed it and problem solved. Sometimes we forget to check simple things, did not expect this in the garage.
Tom G is offline   Reply With Quote
Old 01-08-2019, 04:05 PM   #7
ab_rider
Newbie
Turns out my rear brake was sticking. If I pull up the brake lever with my foot, the problem goes away.
Old 01-08-2019, 05:28 PM   #8
dravnx
dravnx's Avatar
AMA #3018349
Contributor +++++++
Barf Roadside Angel
Motorcycles: '12 DL650A '15 FJR1300A
Riding a bike with a sticky brake can cause the fluid to boil and lockup your brakes. Get it fixed.
bike X miles=smiles
smiles ÷ bike=miles
miles ÷ smiles=bike.
It's simple math.
dravnx is offline   Reply With Quote
Old 01-08-2019, 05:43 PM   #9
mototireguy
Moto Tire Veteran
Valgar beer donor
Contributor +
Did I win the guessing game?
Old 01-08-2019, 07:21 PM   #10
dravnx
dravnx's Avatar
AMA #3018349
Contributor +++++++
Barf Roadside Angel
Yep, you win 2 hobo dollars. Collect at the door.
bike X miles=smiles
smiles ÷ bike=miles
It's simple math.
Old 01-08-2019, 09:00 PM   #11
unobtanium
FOG
Motorcycles: KTM Superduke 1290R Aprilia is dead to me
You must be present to win
unobtanium is offline   Reply With Quote
