Net-Moto :: Community :: Racing :: :: Racing Videos | Sponsor :: Contact |
Forums
Features
Trackdays
Moto Crash Incidents
Race Team
CMSP Training
Sponsors
Donate
Terms of Service
Home UserCP Register Calendar Members FAQ Search |
#1 | |
drtm-B
Motorcycles: The Mistress
DRZ400SM Stock Handlebar Angle
I'm wondering if anyone has some guidance on what could be the best angle to setup the handlebar of the DRZ for a tall person. I have already changed the seat to an SDG tall seat but the handlebar feels strange.
It is currently set for the mid range (3 I believe) which seems to be the same angle the forks are (parallel to the forks). I'm not planning on changing the current fatbar it comes with unless there is no other option. Thanks in advance.
#2 |
MSF/MTC CMSP Instructor
Motorcycles: BMW R1200R, FZ09, FZR400, CR250R
Handlebars and the angle thereof is individual. Get on the bike, put the handlebars in the location and angle that is comfortable for you. There are risers to change the height and a myriad of optional handlebar bends to choose from. Keep in mind width is selectable by trimming the ends off...
<stands, raises hand> Hello, my name is George and I am a motorcycle addict! Please come to one of my MSF, Total Control or CMSP classes and allow me to share my addiction with you. Total Control MTC, IRC and ARC instructor http://www.valleymotorcycletraining.com/signup.html The best performance upgrade is upgrading the operating system of the operator. It is cheap, easy, fast, safe and works on every bike you will ever ride. I am also a Patent Attorney so if I can help you with any IP matters, please just ask. |
#3 |
RYD!
Contributor +
Motorcycles: Big to small.
I like 'em all.
950ADVS-450EXC-R100GS-TW200-YW50P-XR600-Z1-ST90-model165Hummer
As George said...
Also... keep in mind that if you do go taller (risers or bars) you will reach a point that your current cables(s) will not reach. Taller and wider exacerbates this. Once mounted make sure you have cable play from steering lock to lock.
A gooD VoyagE Needs The Unexpected RoutE! It didn’t look that far on the map. Two wrongs don't make a right but three lefts do! |
#4 | |
drtm-B
Thanks folks
#5 |
Don’t forget to change lever position if needed after adjusting the bar.
It's not the answer that enlightens, but the question. - Eugene Ionesco Let us not pray to be sheltered from dangers but to be fearless when facing them. - Rabindranath Tagore A mind all logic is like a knife all blade. It makes the hand bleed that uses it. - Rabindranath Tagore |
#6 |
AMA #3288739
3% Contributor
Motorcycles: 2008 Ducati Hypermotard 1100 S,
2016 KTM 250 XC-F
Loosen the clamps a bit while seated on the bike. When you rotate the bars forward and back you will see your elbows either come out and away from your body or in towards your body because bars have sweep and rise. I've helped countless people do this on mountain bikes, same bar shape on your DRZ. It is very personal, but there is a lot of theory that shows having a natural bend in your elbows causes less fatigue. Also, having your shoulder to elbow to wrist relationship somewhat neutral will prevent you from making unnecessary inputs into the motorcycle. As said above, once you get to a position you like, adjust the levers accordingly. Obviously this doesn't apply to sport bikes, but works well on dirt bikes, or any bike with a dirt style bar mounted on clamps above the triple tree.
Thread Tools | |
Display Modes | |
