Go Back   BARF - Bay Area Riders Forum > Sponsors > The Suspension Forum Presented by GP Suspension
Old 04-27-2017, 06:52 AM   #1
MarktheShark
Gear head on 2 wheels
MarktheShark's Avatar
Motorcycles: 2004 Ex250, 2001 GSF1200s Suzuki Bandit Current: 2001 Sv650s
2001 Bandit GSF1200S fork seals leaking.
Hello,
Recently purchased a Bandit from our friend Antonio with Z2 track days. He informed me that Jason from GP suspension set it up. I have a few questions 😁.
-If I way 205 and am 5'8" is there a preload setting I can just set it to, or do I need to find the mid point of the shock stroke?
- what fork seal oil should I use when replacing the seals?
- do you recommend I get the fork brace that is common for this bandit? Or does it make no difference at all?
Best wishes,
MarktheShark
MarktheShark is offline   Reply With Quote
Old 04-27-2017, 12:43 PM   #2
MarktheShark
Oops! I meant Jason from JPH suspension, my apologies.
Old 05-02-2017, 01:33 PM   #3
afm199
afm199's Avatar
Mod Alumni
Founding Member
Top Percent Poster
I'll throw this out. If the previous owner had the forks resprung, they will be right for the last owner. If you weigh the same he does, they will be close.
Otherwise they are way soft and need revalving, both compression and rebound. I wrote an article on it somewhere on the innerwebs
Old 05-03-2017, 10:51 PM   #4
Snaggy
Semper Pedantis
Snaggy's Avatar
Motorcycles: GSXR's
Congrats on Bandit. Hope you found Maximum_Suzuki and Dale Walker's Holeshot for all things Bandit.
The Bandit's always been a drag racer and wheelie factory more than a canyon carver. Fifteen years ago the motor was a pretty big deal. Now it's retro style. Dale Walker says that an "aggressive rider can really tell the difference" with the $150 fork brace. You'll never completely compensate for the vague frame anyway. I thought stainless steel brake lines and good brake pads were a decent investment.
My fork seals went out at around 15K miles. I paid to have the work done.
Snaggy is offline   Reply With Quote
Old 05-04-2017, 06:42 AM   #5
motomania2007
MSF/MTC CMSP Instructor
Motorcycles: BMW R1200R, FZ09, FZR400, CR250R
Like Ernie says above.
My suggestion is to take it to a suspension tech. There are many good ones in the area.
Let the suspension tech set the preload, etc. And they will tell you if you need springs, revalving etc. and can replace the seals while you are at it.
Since Antonio is not 200 lbs, I suspect you will at least need new springs.
<stands, raises hand> Hello, my name is George and I am a motorcycle addict!
Please come to one of my MSF, Total Control or CMSP classes and allow me to share my addiction with you.
Total Control MTC, IRC and ARC instructor
http://www.valleymotorcycletraining.com/signup.html
The best performance upgrade is upgrading the operating system of the operator. It is cheap, easy, fast, safe and works on every bike you will ever ride.
I am also a Patent Attorney so if I can help you with any IP matters, please just ask.
motomania2007 is offline   Reply With Quote
Old 05-04-2017, 08:01 AM   #6
neroneuman
Rookie
Motorcycles: fzr
These are the Bandit Threads which have been running for long time.
http://advrider.com/index.php?thread...t-1250.280232/
http://www.twtex.com/forums/forumdisplay.php?f=94
You can do the Racetech Straightrate springs and Gold valves along with fork brace and steel braided lines to firm up the front end. I have read that a fork brace on the bandit really makes a difference compared to other bikes. Racetech Gold valves are compression valves and when you buy it, they give a code to access their suspension setup database and they give recommendation for your fork oil weight, air gap, shim stack, spacer length etc based on your weight and riding style.
Generally Racetech's recommendations are on the firm style and setting up one or two notches lower will be good.
But again Racetech's recommendations are generic. A good suspension tech will be able to set you up with Pre-load etc. I bet Rob at evolution suspension will take care of you.
Even after all the suspension farkles, Bandit is no sports bike and will handle good within its limitations.
Bandit's 1200/1250 engine is a gem and you can extract so much HP and TQ with very less money on mods.
neroneuman is offline   Reply With Quote
Old 05-04-2017, 05:06 PM   #7
bunnygoat
bunnygoat's Avatar
Contributor
Motorcycles: 950SM
I have installed the gold valves and they provide a limited improvement. A better solution would be a complete front end transplant. Sounds drastic and expensive, right? Not really.
bunnygoat is offline   Reply With Quote
Old 05-04-2017, 05:49 PM   #8
Smash Allen
a comedy of errors
Smash Allen's Avatar
AMA #: 3283336
Contributor ++
Motorcycles: S1000RR, FZ09, SV650, YZ250
He has access to a garage and tools and peanut gallery (me), a front end swap will be fun. Just need to get him to stop spending his money on his snooze-aroo!
Smash Allen is online now   Reply With Quote
Old 05-04-2017, 07:44 PM   #9
bunnygoat
bunnygoat's Avatar
Contributor
Motorcycles: 950SM
I agree!
Old 05-06-2017, 04:24 PM   #10
Hoho
Ride to Eat
Hoho's Avatar
AMA #: 2760367
Contributor + + + + + +
Motorcycles: Yamaha Hopper
For your fork seals, try Seal Mate first. As simple as it is, it actually does a good job.
As for your preload settings, take it to a tech to get the sag set right, as others have mentioned.
Hoho is offline   Reply With Quote
