Go Back   BARF - Bay Area Riders Forum > Sponsors > The Suspension Forum Presented by GP Suspension
Old 05-10-2017, 09:04 AM   #1
Haket
Haket's Avatar
Contributor
Motorcycles: B12 / Ural / C70 Cub / K1600GTL / S1000XR
Increase front ride height ? GSXR
I'm like to increase the ride height of a 06'GSXR 750 fork by 1-1.5inch. Any way of doing this in a cost effective manner ?
Its used on a project bike that's original forks are 2inch longer so handling is a little quick (rear is also jacked up. I've dropped the forks in the yokes as much as possible. A stepped yoke is too much $$$.
Haket is offline   Reply With Quote
Old 05-10-2017, 07:52 PM   #2
zammer
Tripler
zammer's Avatar
AMA #3004877
1% Contributor
Motorcycles: '09 Triumph Street Triple R, '07 GSXR-750 (Track)
I think fork extender caps are your only option. I'm in the same boat right now. I think without caps, running the front end flush with the top triple and rear around 322-323mm eye to eye is about as high as the bike can get (from my reading).
Edit: fixed shock length numbers
zammer is offline   Reply With Quote
Old 05-10-2017, 07:59 PM   #3
Haket
Haket's Avatar
Contributor
Best option I've seen is the +20mm from Traxxion
http://www.traxxion.com/Extended-Sho...-Cap-for-GSXR/
+15mm from GP
http://gpsuspension.com/Fork-Cap-Extender_p_20476.html
Any others you've found ?
Old 05-12-2017, 04:25 AM   #4
Mtfuzzy17
Newbie
Motorcycles: ZX10R
too much $$$.
40mm's is alot. Most do maybe 20mm.
Even at this you will need custom brake lines to fit an extended fork.
We have the fork extenders for an OEM fork or you can completely upgrade and get a set of GP Suspension 25mm carts.
We can help set up your entire chassis.
www.gpsuspension.com
(805) 251-1400
2041 Cabot Place, Unit F Oxnard, CA 93030
Winning. Every. Day.
Mtfuzzy17 is offline   Reply With Quote
Old 05-12-2017, 06:57 AM   #5
Triple R
Triple R's Avatar
Contributor + 1%
Motorcycles: Get me injured and in trouble!
If I remember correctly, the M4 guys back in the day (06/07 GSXR 600/750) machined the bottom "step" from the top triple to gain a few more mm. Cost effective way of gaining some more adjust ability.
Triple R is offline   Reply With Quote
Old 05-14-2017, 10:06 AM   #6
afm199
afm199's Avatar
Mod Alumni
Founding Member
Top Percent Poster
There's no way to get 1.5 inches. You can pull the forks and cut the internal rebound spring down to lengthen them slightly ( maybe 1/4" ). However this places the end of the fork tube (inner) onto the bushing at maximum extension. You really want to be careful with that. You can get 1/2" to 3/4" with a fork extender cap. That's about it. And I suggest you shorten the shock at this point. Making it longer is just going to put yet more weight on the front end.
afm199 is online now   Reply With Quote
Old 05-14-2017, 10:07 AM   #7
afm199
afm199's Avatar
Mod Alumni
Founding Member
Top Percent Poster
Originally Posted by zammer View Post
i think fork extender caps are your only option. I'm in the same boat right now. I think without caps, running the front end flush with the top triple and rear around 522-523mm eye to eye is about as high as the bike can get (from my reading).
323-330?
Old 05-14-2017, 03:58 PM   #8
zammer
Tripler
zammer's Avatar
AMA #3004877
1% Contributor
Whoops, fixed.
Old 05-15-2017, 02:52 PM   #9
stangmx13
not Stan
stangmx13's Avatar
Contributor
BrotoGP
forks can be run recessed in the top triple. i ran 5mm recessed for a while.
aftermarket cartridges can be built longer. some Ohlins are ez, u just remove/change two spacers. others are more difficult.
Follow me on IG @rwpierce13
Thanks to: RiderzLaw Vortex
Old 06-12-2017, 09:58 AM   #10
LabRat675
LabRat675's Avatar
Contributor
Motorcycles: 1290 SUUUPER Duke MV Agusta F3 675
Just stumbling across this thread, i'm assuming OP meant "shorter" by 1-1.5". Which means they are most likely gsx-r1000 forks. I swapped in some Ohlins kit forks for a 1000 and made custom caps that were around 2" longer so I could get the right ride height out of the setup. Nothing off the shelf, swapping things on project bikes often needs $pecial parts.
LabRat675 is offline   Reply With Quote
Old 06-12-2017, 01:16 PM   #11
Haket
Haket's Avatar
Contributor
I ended up using the 25mm fork caps, though I need more testing to make my mid up. Definitely slowed the steering down. I have sourced a stepped top yoke but am unsure if that'll be too much of a lift.
My cables etc will still fit as I can reuse the original lines (love Suzuki interchangeability)
Bike I'm tweaking:
Old 06-13-2017, 09:15 AM   #12
afm199
afm199's Avatar
Mod Alumni
Founding Member
Top Percent Poster
Swweet B12
