220v Lithium battery charger?
norcalkid
Active member
NorCal
DL650
CRF250 Rally
Yamaha Aerox 155
Africa Twin
I know this is a kinda weird question but do any of you happen to know of a Lithium battery charger that will run on 220v power? I recently picked up a Africa Twin with a Lithium battery here in Thailand. I was hoping to pick up a charger when in the US next week (can't find one here) but it has to be 220v European style power.
Thanks
Can't you buy a typical US Lithium charger and then use wall socket adapter?
That's how ran my laptop when I when I was in Bankok.
Laptops and phones are dual voltage, a simple adaptor works. That's not the case with other stuff not built for travel. You need a step down adaptor which is just one more thing to buy and break. (that's my backup plan if I can't find a charger that's built for the European market.
I'm actually thinking of trying to put a 110v plug in my condo but not sure how as 220v runs in on one wire not 2 like in the US.
Do you actually need a charger? Li batteries self-discharge way slower than Lead ones. And they will probably sustain small draws for longer too. So you may not actually need a charger.
If your bike is going to sit for months, you should disconnect the battery. Then charge it once with a low amp charger and go ride. If your bike isn’t going to sit, I wouldn’t bother with a charger.
How do you know that?? Or are you saying you are sold?
This. Lithium batteries have virtually 0 self discharge.
thanks, My bikes always sit as I spend half the year in the US and half in Thailand. So I always have a bike sitting at one end.
Ya, you should absolutely disconnect the batteries when you leave. Theyll probably be healthier than sitting on a charger.
My race bike has run 3x in the past 2yrs. It has a Li battery with zero draw when off because of a race harness. I haven't had to charge it. I may use a dumb battery tender next time I go to fire it up, might not. It'll fire right up.
I’d look for a smart charger in a country that uses the same voltage that Thailand uses. Should be relatively simple to find.
Ya, their all disconnected
We replace the Lithium batteries in aircraft emergency location transmitters after 5 years and they are still fully charged. I have a couple of rarely used flashlights that have Lithium batteries that are over 15 years old.
