BARF - Bay Area Riders Forum
Old 05-12-2019, 09:25 PM   #1
Siris
Rookie
Motorcycles: ‘17 Tuono
Rounding nuts, bolts and scratching frame/fairing
No matter how careful I am, I find myself rounding nuts or bolts (tool slipping) or scratching frame/fairing from tool slips. Not sure how one gets better at not doing this. Just need one rushed evening to finish a job or mind not fully in it, and bang, it happens. Hurts more on new bikes or cars.
Is this just my ineptitude or is this common? Those aluminum hardware are the worse! Even when doing it right, the sharp corners start rounding - so when tool slips, almost feel like replacing the component entirely.
Worse is when it happens on frame/fairing and scratches it up, which arenít easily/cheaply replaceable.
I have seen even pros do it where I go in for a simple job and get the bike back sometimes with scratched up fairings or rounded bolt heads or nuts.
Siris is offline   Reply With Quote
Old 05-13-2019, 04:07 AM   #2
423yjl
shaky
Contributor
Motorcycles: m900si.e
not all tools are the same, some have tighter tolerances than others. some can flex and warp. worn tools can have more play in them also.
try to use only 6 sided sockets as opposed to 12
I've had even well respected pros leave marks on things, that is why I try to do whatever I can myself, to the bike.
423yjl is offline   Reply With Quote
Old 05-13-2019, 01:52 PM   #3
Siris
Rookie
I do only use a hex socket. I generally shy away from the universal types. As for tighter tolerances, I have a Husky set from Home Depot. Not sure if there's a certain brand that's consistently better than others in tolerance and material.
My issues is usually with the wrenches and allen keys. I stopped using the adjustable wrenches too cause I know I always screw things up with those.
Old 05-13-2019, 02:16 PM   #4
stangmx13
not Stan
stangmx13's Avatar
Contributor
BrotoGP
T-handles help a lot with allen bolts. its much easier to apply your torque in the perfect direction.
use the box end of a wrench as much as possible even if its 12-pt.
try to apply some inward force towards the nut/bolt with all tools. this helps a lot.
Follow me on IG @rwpierce13
Thanks to: RiderzLaw Vortex
Old 05-13-2019, 04:11 PM   #5
ST Guy
ST Guy's Avatar
Adjustable wrenches suck, as you've found out.
With allen wrenches, buy quality wrenches and make sure the ends of the hex are flat and sharp. They can be ground down on the end to make them that way. They "bite" better in the fastener that way.
Also, the L shaped allen wrenches are hard to keep from bending in the wrong way simple because of their shape. Get allen wrenches that either have a screw driver type handle or a T handle. T is probably best as you can apply more torque that way.
In general, you'll learn more as you do more. And you've got part of it figured out already. As you've mentioned, being tired, rushed or simply don't have your mind focused on your work is the time to stop and walk away. It's one of the earlier lessons from Zen and the Art of Motorcycle Maintenance.
Old 05-13-2019, 06:31 PM   #6
ejv
Untitled work in progress
Motorcycles: Tuono
The only thing I know that fixes this is better tools. When I got my Tuono I actually went and got some real tools, from Granger. Haven't had any issues wrenching on the Tuono at all. I don't recall the specific brands I got from Granger but is spent some money for sure.
ejv is offline   Reply With Quote
Old 05-13-2019, 07:28 PM   #7
splat
splat's Avatar
Motorcycles: Mostly red ones
Is your bike standard or metric? Are the allen wrenches you're using standard or metric? JIS screw driver?
[this space for rent]
splat is offline   Reply With Quote
Old 05-14-2019, 09:47 AM   #8
auntiebling
megalomaniacal troglodyte
auntiebling's Avatar
BARF Moderator (ooh, fancy!)
Barfie Winner 2017
Contributor
Motorcycles: .
this is not an Adjustable Wrench
it is either a
A)Nut Fucker(upper)
or
B)Caliper
it is really only any good at (A) and you'd better have a tolerance of +/- 0.125" or greater for (B)
no shirt, no shoes: No dice BARF TOS
every book is a children's book if the kid can read
-mitchbarf memes
my dad is an engineer
17/38 sprockets
CARB bikes list CA DMV fee calculators
Classifieds Forum Rules
Originally Posted by Abacinator View Post
Love that subway tile backsplash, auntie
auntiebling is offline   Reply With Quote
Old 05-14-2019, 10:32 AM   #9
jaybocc2
o lento
AMA #3692962
Motorcycles: 05 zx10r (street), 11 zx10r (track), 13 zx10r (race)
it is either a
A)Nut Fucker(upper)
or
B)Caliper
When you're working on a late 80s GM car you'll need a few of those... eliminates the guesswork of whether or not the bolt/nut you're about to attack is metric or SAE...
AFM #705 | youtube | instagram | facebook
Please give some love to my 2019 Sponsors!
Daredevil Motorsports | Amsoil | SPY Optic | GoPro
jaybocc2 is offline   Reply With Quote
Old 05-14-2019, 11:39 AM   #10
dravnx
dravnx's Avatar
AMA #3018349
Contributor +++++++
Barf Roadside Angel
Motorcycles: '12 DL650A '15 FJR1300A
I thought that was called a hammer.
bike X miles=smiles
smiles ų bike=miles
miles ų smiles=bike.
It's simple math.
dravnx is offline   Reply With Quote
Old 05-14-2019, 11:49 AM   #11
auntiebling
Barfie Winner 2017
Contributor
Motorcycles: .
perhaps you are thinking of the Thumb Detecting Nut Fucker?
-mitchbarf memes
17/38 sprockets
Old 05-14-2019, 12:00 PM   #12
OaklandF4i
Darwin's exception
OaklandF4i's Avatar
Founding Member
Barfie Winner 2017
Contributor ++++
Motorcycles: Triumph Street Triple, YZ250, TLR200, XR400R, Husqvarna CR390, ST1100 and couple more...
Rarely round off nuts or bolts anymore. The right tools, good tools, and experience. Does it happen still? Occasionally, but rarely.
Great tip on grinding down Allen head sockets to sharpen. I always just replaced.
I'm looking for 1970 or older project like a CB350 or Triumph 650. Cheap and complete. PM me if you have something - will provide it a good home.
If you think me being naked is offensive, dont look!
"You find the biggest meanest bull, chop off his balls, dangle them in front of him, then hop on his back. That should give you some reference point. Either that, or shove a shuttle rocket up your ass. Take your pick." Colin Edwards
'Cycles is a mean toy lady" Big Halsy
OaklandF4i is offline   Reply With Quote
Old 05-14-2019, 12:57 PM   #13
Sofa88
Rookie
Motorcycles: R3
Offset hex wrenches and universal joints for those tight areas help a lot too. When there’s shit in the way from letting your tool get a good bite on a bolt don’t risk using a regular wrench because you’ll probably round it when you slip from the awkward angle.
Sofa88 is offline   Reply With Quote
Old 05-15-2019, 09:03 AM   #14
Siris
Rookie
That's a good tip. I need to buy a decent set.
Great tips! And that book is great but goes from a light casual read to super deep pretty fast once he gets deep into aspects of Quality! Will have to go back and reread again one of these days.
No doubt Grainger carries quality stuff as they're mostly targeted for industrial and professional use. I buy mostly from Grainger at work. But man, they are super pricey! I have to start wrenching a lot more before I can do justice to those tools! Husky hasn't been bad - its been mostly user error on my part that's led to most of my grievances.
Originally Posted by Sofa88 View Post
Offset hex wrenches and universal joints for those tight areas help a lot too. When thereís shit in the way from letting your tool get a good bite on a bolt donít risk using a regular wrench because youíll probably round it when you slip from the awkward angle.
Those tight areas are the most problematic 'cause I can't always get the tool at a good angle or have adequate leverage. I was trying to tighten couple locknuts on my exhaust flapper cable as it had too much slack, and I was propping the exhaust with my legs and one hand, while snaking my hand around in a tight space to get just enough leverage to tighten the locknut. Managed to slip and round off an edge of a nut. Part of that was I was rushing it a bit as it was late at night and needed to get up early for work. Tools with better reach would probably have helped too.
Old 05-15-2019, 09:13 AM   #15
thedub
Octane Socks
thedub's Avatar
AMA #: 2952025
Motorcycles: R6, Tiger 800, KTM 500, KTM 350
I use these two t-handle sets 80% of the time.
T-Handle, Ball-End Hex, Dual Drive, Metric Set (4,5,6,8mm)
T-Handle Set, 7 Pc Metric
AFM #77, D36 #166N
Thanks for the support;
Sidi|Motion Pro|C@TT|Vortex|Shoei
thedub is offline   Reply With Quote
