BARF - Bay Area Riders Forum
Go Back   BARF - Bay Area Riders Forum > Community > Kitchen Sink
Notices
Old 09-27-2020, 05:15 PM   #1
Nick
Uncarlfarbmanlike
Nick's Avatar
BARF Moderator
Founding Member
Contributor +
Motorcycles: 2004 Honda Metropolitan
Torque Converter Lock Question
Didn’t really find what I was looking for online, so I figured I’d ask the BARFs.
I recently bought a 2006 Dodge Ram 3500 with an 4-speed auto with OD trans. The truck came with a BD Diesel Exhaust Brake and with the exhaust brake activated (toggle on/off for towing), the converter locks at like 25mph instead of the 50mph in standard Drive.
It got me thinking..... Is there any drawback to having the converter lock up so early for regular driving (other than rougher shifts). It obviously protects the trans from running hot with the converter slipping all the time, but is there a risk at all to having it lock early? Why don’t auto trans just lock up early all the time?
There’s gotta be something I’m missing.
BARF Terms of Service
Nick is offline   Reply With Quote
Old 09-27-2020, 06:16 PM   #2
Mike95060
Work In Progress
Mike95060's Avatar
Founding Member
Contributor +
Motorcycles: 2004 Ducati ST4S
Because when they lock they don’t multiply torque when you need it maybe?
DARE MIGHTY THINGS
We all lead by example, even when we don't think we are...
-Grosso
Mike95060 is offline   Reply With Quote
Old 09-28-2020, 06:23 AM   #3
msethhunter
msethhunter's Avatar
Contributor
Motorcycles: '98 VTR1000F, she's a fatty! '89 YSR 50 with a 150, she said "it's so cute!"
I was a Diesel tech for Dodge when I was a wrench. I got out when your generation truck was being produced. There was a lot of problems with them burning up pistons when they went to the common rail system. Anyways, the speed when the converter locks was set as a compromise between NVH (noise vibration and harshness) and fuel economy. If memory serves correct, the set it where they did to keep the transition smooth.
Personally, I'd leave it be. Your truck makes gobs of torque and the transmission is the weakest link in your drivetrain. If memory serves, it's a 48RE. The 4 is for 4spd, the 8 is for 800ftlbs capacity, R is for rear wheel drive and E for electronic control. The weak link in your transmission is overdrive and the converter. It's not usually hard parts that fail. It's usually the clutches.
I may seem like an asshole, but I'm mostly just a sarcastically driven prick. It's not personal.
msethhunter is offline   Reply With Quote
Old 09-28-2020, 07:24 AM   #4
Nick
Uncarlfarbmanlike
Nick's Avatar
BARF Moderator
Founding Member
Contributor +
So early lock is better for the trans or worse?
Old 09-28-2020, 07:39 AM   #5
msethhunter
Contributor
I generates less heat, but is harder on hard parts. Heat is usually what kills an automatic transmission. But diesels break hard parts with their massive torque.
It's not a simple question with a simple answer.
Old 09-28-2020, 07:56 AM   #6
Nick
Uncarlfarbmanlike
Nick's Avatar
BARF Moderator
Founding Member
Contributor +
Makes sense. I’m not beating on the truck hard at all. I did the fast diesel thing with my 6.4L Powerstroke. I’m just interested in longevity and reliability.
Old 09-28-2020, 09:08 AM   #7
stangmx13
not Stan
stangmx13's Avatar
Contributor
BrotoGP
I was thinking this exact thing. Torque multiplication can be very useful. Id probably be unable to pull my boat with my tiny truck without it. But I'm pretty much guessing.
Follow me on IG @rwpierce13
Thanks to: RiderzLaw Vortex
Old 09-28-2020, 09:50 AM   #8
KWeezyXB12
SKRRRRRRRRRRRT!!!!!!
KWeezyXB12's Avatar
Motorcycles: 2002 yz 250
if you do need a trans ever i recommend suncoast or make the trip to randys transmission. ats is ok but i hear people having issues but ats is pretty good about warranty stuff and replacement. i had a 06 with a suncoast and it was great. if you get the bug for bolt ons go banks as its all carb legal. i did their complete intercooler kit, intake and 6 gun tuner.
Petey
KWeezyXB12 is offline   Reply With Quote
Old 09-28-2020, 12:28 PM   #9
msethhunter
Contributor
Keep it cool then. I'm not sure you'll gain much by locking the converter earlier in terms of efficiency, and you may be dissatisfied with how it drives, but it's worth a try. If you do end up going to a manual control of your TCC, look into a kit that will also raise the line pressure as well. Line pressure = greater clamping force for the clutches. It'll probably shift a little harsher, but quick shifts reduce heat. Hard shifts break stuff.
Old 09-28-2020, 09:15 PM   #10
Nick
Uncarlfarbmanlike
Nick's Avatar
BARF Moderator
Founding Member
Contributor +
I’m pretty sure the exhaust brake came with trans tuning. With the brake activated, it shifts much harder. I was wrong about converter lock though. It locks at 35mph, not 25mph.
I towed our 40’ toy hauler around a little bit today and the trans stayed right around 215°F the entire time.
Old 09-29-2020, 05:34 AM   #11
msethhunter
Contributor
215° is pretty good, especially towing something that size. A little on the high side but still well within an acceptable range. I'd start to worry once temps got above 250°. At about 265° it's time to shut it down and let it cool, and change the fluid.
Old 09-29-2020, 06:38 AM   #12
scootergmc
old and slow
scootergmc's Avatar
Motorcycles: Honda HT3813 (x2), Cub Cadet 147, Oliver 1655, Super 88, Cat 15 (x2), Yam FJR
Is your temp sensor inline precooler or in the pan? I'm assuming it has a double deep pan as well as the exhaust brake? Who built the tranny?
Are you a member of the TDR? The same information can be found on cumminsforums, etc., but it's worthwhile ($35?/yr.) for the forum plus the magazine:
https://www.turbodieselregister.com/forums/
scootergmc is offline   Reply With Quote
Old 09-29-2020, 07:25 AM   #13
TheRobSJ
Großer Mechaniker
TheRobSJ's Avatar
Founding Member
Contributor
Motorcycles: No bike until I have a bigger garage.
Exactly that. This is why the big boy drag racers have high stall speed converters. This is why converters go into lockup at light throttle/cruise conditions, but immediately disengage as soon as you feed in even moderate throttle.
Also they stay disengaged at slower speeds to maintain driveline smoothness and of course not stall the engine when you come to a stop. Think of driving a stick shift car in the first two gears...if you come on and off the throttle in even a slightly abrupt manner, it gets awful “trailer hitchy” doesn’t it? With all the slack in a typical full size truck drivetrain, this trailer hitching effect would be a bit more dramatic and just bad for all the parts involved.
TheRobSJ is offline   Reply With Quote
Old 09-29-2020, 08:29 AM   #14
Mike95060
Work In Progress
Mike95060's Avatar
Founding Member
Contributor +
Holy shit I got one right!!!
Thanks Rob.
DARE MIGHTY THINGS
-Grosso
Old 09-29-2020, 08:40 AM   #15
msethhunter
Contributor
The "big boy drag racers" have high stall convertors to get into/closer to the power band at launch. Too high of a stall speed will actually make the car slower at the top end of the track because a converter that doesn't lock with a clutch never stops slipping.
Think of it more as a clutch. Yes, there is some torque multiplication happening but it's not much different than slipping the clutch in a manual. But it allows the clutches in the transmission to lock and the converter to "slip" in place if a manual clutch.
