Old 01-15-2019, 09:04 AM   #1
berth
berth's Avatar
Motorcycles: KRS-1200
Friend has a fuel with with a 250 Ninja
Posting for a friend, I'll just quote it:
Got a maintenance quandary for y'all. Have a problem that's happened twice in about 3 years. Bike ('09 Ninja 250) doesn't start after being off for a couple of weeks (first time was 3 weeks, this time was 12 days). Both times the tank has been relatively empty but had gas. Engine turns. There is an occasional light backfire after attempting for a while, but no smell of gas as if my engine were flooded.
After the first time I have left the bike off for similar time periods with a full tank and not had the issue; I just forgot this time. Part of me feels that the level in the tank is me being superstitious, but that's could be just me not understanding what the cause could be.
Both times, to fix it I drained my carburetor bowls (second time I also had to recharge my battery but that was more due to draining it after trying to start so many times, so likely secondary), so the running theory is that there's some condensation/water getting in them.
41000 miles.
Wondering what the cognoscenti think. It's his daily commuter.
#69
berth is offline   Reply With Quote
Old 01-15-2019, 09:43 AM   #2
motomania2007
MSF/MTC CMSP Instructor
Motorcycles: BMW R1200R, FZ09, FZR400, CR250R
About a hundred different possibilities given that slight amount of data to go on.
Fuel in several different ways is certainly some of the possibilities.
<stands, raises hand> Hello, my name is George and I am a motorcycle addict!
Please come to one of my MSF, Total Control or CMSP classes and allow me to share my addiction with you.
Total Control MTC, IRC and ARC instructor
http://www.valleymotorcycletraining.com/signup.html
The best performance upgrade is upgrading the operating system of the operator. It is cheap, easy, fast, safe and works on every bike you will ever ride.
I am also a Patent Attorney so if I can help you with any IP matters, please just ask.
motomania2007 is offline   Reply With Quote
Old 01-15-2019, 09:59 AM   #3
stangmx13
not Stan
stangmx13's Avatar
Contributor
BrotoGP
ya, hes prob flooding the engine while trying to start.
the engine probably needs some maintenance to improve starting. that way the tiny amount of water that gets into fuel doesnt fully prevent it from firing.
Follow me on IG @rwpierce13
Thanks to: RiderzLaw Vortex
Old 01-15-2019, 10:18 AM   #4
berth
berth's Avatar
What more data do you think would be useful?
Well he says he's not smelling gasoline, so that's why he doesn't think he's flooding it.
Do you think it needs some extended maintenance? over and above "routine" maintenance (for assorted values of "routine"). What maintenance do you think may be lacking?
Addenda, it has not had the valves adjusted in the past 20K, but they've been adjusted before, if that's any help.
#69
Old 01-15-2019, 10:47 AM   #5
motomania2007
Most likely possibilities:
weak battery
plugged fuel circuit(s) in the carbs
vacuum leak preventing the petcock from flowing fuel
out of speck valves causing hard starts
contaminated fuel
The first things I would check are the simple items:
1) How strong is the battery after a full recharge and load test.
2) Clean and tighten all 6 battery cable connections.
3) Make sure the spark plugs are recently replaced
4) Inspect all fuel lines and vacuum lines for cracks and leaks
5) Are the valve clearances in spec?
6) Once it is running, how stable is the idle? Does it idle with the choke turned off?
That gives a basic condition of all the parts involved and if all of that is very healthy then I would dig a little deeper and the next thing I would do is pull the carbs and clean the insides to make sure all the circuits and jets are clean and functional. I suspect one or both pilot circuits are plugged or partially plugged.
Old 01-15-2019, 10:53 AM   #6
berth
berth's Avatar
Thanks, George. That list looks really helpful and I will pass it along.
#69
Old 01-15-2019, 11:08 AM   #7
stangmx13
not Stan
stangmx13's Avatar
Contributor
BrotoGP
draining the carb bowl is a trick I used to use on my dirt bikes after I had flooded it. im not sure why it worked.
pretty much +1 motomania. clean carbs and proper valve clearances make a bike a lot easier to start.
Old 01-15-2019, 11:29 AM   #8
Maddevill
KNGKAW
Maddevill's Avatar
AMA #: 542337
Motorcycles: ZX14,GS750E, RM250
Ninja 250 has a history of valves tightening up. If you have tight valves, at start up you are losing compression due to valves hanging slightly open. On that bike, ANY loss of compression makes it harder to start. Usually it shows up when the motor is hot though. And tell your friend not to store the bike with an empty tank. Invites rust.
Mad
Old 01-15-2019, 11:54 AM   #9
berth
berth's Avatar
He doesn't leave it parked for long.
Recent anecdote:
That's what happened last time this issue cropped up, which was after the holidays. Was parked with half a tank for the holiday week, started up okay did fine until I got off the freeway and then stalled as I was getting into work. Kept the choke on a little going back home, filled up the tank, did fine the next day. Didn't have to drain the bowls like I did years previously.
I find it interesting that it starts up fine, and then has problems later in the day.
Sitting for 5 days shouldn't be a real problem for anything.
#69
Old 01-15-2019, 12:27 PM   #10
motomania2007
There are tons of possibilities still.
I suspect the carbs being partially plugged up and probably also a weak battery as these are the common culprits but valve clearances being wrong will also cause issues...
Old 01-15-2019, 12:29 PM   #11
295566
Five Apples
295566's Avatar
Contributor +
Motorcycles: 07 R1, 85 GPZ900R, 99 SV650 (track)
x2
Sounds like your friend's bike can use some maintenance, it definitely won't hurt! Pull the carbs and thoroughly clean them, do a valve adjustment, and test the battery (or replace if it's been more than a few years since that has been done). Inspect all vacuum lines when reinstalling the carbs too. That should be a good start.
295566 is offline   Reply With Quote
Old 01-21-2019, 02:15 PM   #12
berth
berth's Avatar
So, here's a follow up after a bit of work over the weekend.
new sparks and cleaned out the carb, no dice. Don't think this is my typical issue of days past. Still having a low idle and a loss of power. I do get occasional chugging where it feels like the power kicks in. Gonna check simple things like cleaning the air filter over the week and then probably take a look at valves next weekend when I have time.
Does this sound like a valve issue?
#69
Old 01-21-2019, 02:54 PM   #13
mototireguy
Moto Tire Veteran
mototireguy's Avatar
Valgar beer donor
Contributor +
Possible gas tank breather not breathing.
Is there any whoosh sound when opening the gas cap?
Try starting/running bike with gas cap cracked open.
Vacuum operated petcock type bike?
Try running the petcock in Res/Prime position.
Possibly weak battery or charging system kaput.
What is the battery voltage key-off?
What is the battery voltage bike-running?
And valve clearance check, if within spec then easy task very much worth checking, not assuming/guessing.
mototireguy is offline   Reply With Quote
Old 01-21-2019, 04:06 PM   #14
bobl
Contributor
Motorcycles: ZX6 Kawasaki
Does the 250 Ninja use a fuel pump to deliver gas to the carbs? If the fuel tap is below the carbs, many bikes use a 2 to 4 psi pump for delivery. Sometimes if the tank level is well above the carbs, it will gravity feed to the carbs. Level gets low and it needs the pump. I don't know about the Ninja 250, but worth a look if it has a pump.
bobl is offline   Reply With Quote
Old 01-21-2019, 05:36 PM   #15
Junkie
re-tarded
Junkie's Avatar
Contributor + 3%
I don't believe it uses one. I know the 1st gen and 2nd gen were gravity feed, I believe the 3rd gen is too.
