BARF - Bay Area Riders Forum
Old 02-01-2019, 01:38 PM   #1
RSmil
Newbie
Motorcycles: 2007 Suzuki GS500f 2004 Harley Davidson FXDLI
2004 FXDLI Having Starting Issues
Hey Everyone,
Im hoping someone here can help me out. I have a '04 Lowrider with fuel injection.
Problem started when I rode the bike to a friends house, and had it parked for a couple hours. When I came back, the battery was dead, and I had to get it towed home. I put the bike on a trickle charger and let it sit for 2 days.
As of right now, it is having some problem starting up. When I turn it on (not ignition), I'm getting the fuel pump sound, even when the switch isn't flipped, as well as not all of the lights coming on. Then when I turn the key to "ignition", the headlight comes on (nice and bright), and sometimes all of the lights on the dash come on. When I flip the fuel pump switch, I get a clicking sounds, and all of my lights will stutter until they eventually all shut off and the battery dies.
Brief History:
Bike has 12k miles, bought bike at 11k.
Had a 10k Service done in October.
Rode it from SF to Fresno in one day (409 miles) and everything was working perfectly.
Would take it out a couple times a month to run errands, but no long rides.
I have a video of the bike if that helps. I can post it upon request. Thank you to anyone who takes the time to look at this post and decide to help me out.
RSmil is offline   Reply With Quote
Old 02-01-2019, 01:42 PM   #2
Junkie
gone for now
Contributor + 3%
Motorcycles: n/a
What is this "fuel pump switch"? Kill switch?
Sounds like there's some sort of parasitic drain, and a battery that needs to be replaced.
Old 02-01-2019, 01:47 PM   #3
RSmil
Newbie
Yes, the kill switch. What steps would you recommend should I take in order to more accurately diagnose what is going wrong?
Old 02-01-2019, 01:49 PM   #4
splat
splat's Avatar
Motorcycles: Mostly red ones
If the battery was completely flat, a trickle charger will not do the trick. You'll need to either "fool" it to start charging or use an actual charger.
Your best bet is to have the battery charged with an actual charger then have it load tested. If you don't have your own multimeter, auto parts store will test for you for free (they'll charge it for you, too if it's dead). Start from there.
[this space for rent]
splat is offline   Reply With Quote
Old 02-01-2019, 01:52 PM   #5
295566
Five Apples
295566's Avatar
Contributor +
Motorcycles: 85 GPZ900R, 99 SV650 (track)
You mean hitting the starter? or the kill switch on the bar? Red or gray button on this pic?
Either way sounds like a dead battery. Cold weather is not good for batteries, especially on bikes that don't get ridden too often. When was the last time the battery was replaced? I'd start there.
295566 is offline   Reply With Quote
Old 02-01-2019, 01:57 PM   #6
ST Guy
ST Guy's Avatar
It's unlikely that a new, out of what's usual, parasitic draw has occurred. How old is the battery?
Do this before anything else:
1. Put battery on a real charger, not a trickle charger and give it a full charge. (A motorcycle charger, not a car charger!)
2. After a full overnight charge, disconnect the charger and take a reading of the battery voltage. Write it down. Then let it sit for an hour and take a second reading. Then at the two hour mark, take a third reading. The readings at 1 and 2 hours will be the most accurate readings. Voltage readings taken immediately after disconnecting the charger (or shutting off the engine) are artificially high.
3. After the third reading at 2 hours, start the bike and take a reading with the engine at idle and another reading with the engine at 3-4000 rpm.
Report back with all readings.
It could be as simple as the battery is old and toast. But we also want to rule out any charging system problems.
Old 02-01-2019, 02:33 PM   #7
RSmil
Newbie
Thank you, I'll get this work done tomorrow, and get you an update. I really appreciate the step by step.
Old 02-01-2019, 02:34 PM   #8
RSmil
Newbie
From the picture, it is the kill switch, so red button. The starter just gets a low grinding sound, as if the starter motor is getting close to no juice.
Old 02-01-2019, 02:36 PM   #9
RSmil
Newbie
Thank you for getting me started! I'll bring it in to my local part store first thing tomorrow.
Old 02-01-2019, 02:39 PM   #10
mototireguy
Moto Tire Veteran
mototireguy's Avatar
Valgar beer donor
Contributor +
Try jump starting the bike from a KEY OFF car battery.
Report back with your results.
Could be...
Your battery connection terminals are loose.
Your battery is old/toast.
Your bike charging system is kaput and you ran the battery flat/dead. Flat/dead/old batteries don't always recover from time on a battery charger.
mototireguy is offline   Reply With Quote
Old 02-01-2019, 04:40 PM   #11
ST Guy
ST Guy's Avatar
Do NOT have the battery load tested at one of the auto parts stores or any store that uses the newer type electronic battery testers. They do not apply an actual load to the battery but instead, infer battery capacity using other electronic means. An indirect measurement, if you will. And it's notoriously inaccurate. Many times it will tell you the battery is fine when it actually isn't.
Do as I outlined first, before removing the battery. Get it charged and then do the voltage checks. But checking terminal connections before you do all that is a good idea.
If you don't have a multi meter, buy one. It's a basic tool like a socket wrench or screw driver and can be used for many other things like checking things around the home. They're not expensive. I have several, one of which is shirt pocket size which I used to carry with me on the bike just in case.
Old 02-01-2019, 04:42 PM   #12
ST Guy
ST Guy's Avatar
The pocket tester I have looks like this, only mine's yellow and was sold by Radio Shack. (Out of business now.)
https://www.amazon.com/all-sun-Digit...5%3A2470955011
Fry's Electronics will likely have something similar.
Old 02-01-2019, 09:00 PM   #13
RSmil
Newbie
That makes sense. I would rather be doing the work on the bike myself. Much appreciated!
Old 02-03-2019, 11:26 AM   #14
ratsblast
ratsblast's Avatar
Motorcycles: Buell BeLast, steal it, I dare you! 1997 1200xlh
What brand of battery are you running? The AGM batteries harley uses like to die a swift and ignoble death on discharge. If the battery gets below a certain voltage for long enough it is dead. I am liking the MotoBatt batteries they are about 100 shipped to your door.
Charge up the battery, unplug from charger, put voltmeter on battery, note voltage. Turn ignition on and the high beams. If the voltage drops like a rock to below 12v the battery is dead.
ratsblast is offline   Reply With Quote
Old 02-08-2019, 04:44 PM   #15
RSmil
Newbie
I finally got around to testing the battery and the voltage is steady across the board. I measured†both DCV and ACV @500 4 times; while charging, right off charger, 1 hour off, and 2 hours off. DCV held a steady 13, and the ACV is steady at 27.
