Old 02-10-2019, 05:58 PM   #1
Junkie
re-tarded
Junkie's Avatar
Contributor + 3%
Valve checks: do you really need to be at TDC?
This is a general question rather than specific to any given bike.
If I have the cam's lobes nowhere near pushing on the rocker arm or bucket (depending on type), am I going to have any problems from the engine not being at TDC? It's easier to put the cam lobes directly opposite where you measure than it is to see in the little hole where the timing mark is.
I know that for shim under bucket, if you have to pull the cams to adjust you need to get timing perfect, but that's different than checking.
Old 02-10-2019, 08:04 PM   #2
zammer
Tripler
zammer's Avatar
AMA #3004877
1% Contributor
Motorcycles: '09 Triumph Street Triple R, '07 GSXR-750 (Track)
You know it's funny, I had an '02 GSXR 600 and it said to check them lobes facing sideways. I've done maybe a dozen valve adjustments on about as many different models and almost all of them say facing up.. so it's probably not absolutely necessary but probably depends on how degree'd the cams are?
Thing is, i think you get a cleaner 'feel' for how much drag there is when the lobe is upright, so I always rotate the wheel/crank for that cylinder and measure it. Never thought about it a whole lot, wonder what the rest of the garage thinks on this.
zammer is offline   Reply With Quote
Old 02-10-2019, 08:13 PM   #3
thedub
Octane Socks
thedub's Avatar
AMA #: 2952025
Motorcycles: R6, KTM 300, Tiger 800, KTM 500
This is the factory service manual for my Tiger 800. Doesn't even mention TDC.
Name:	Screen Shot 2019-02-10 at 8.12.22 PM.png
AFM #77
Thanks for the support;
Sidi|Motion Pro|C@TT|Vortex|Shoei
thedub is offline   Reply With Quote
Old 02-10-2019, 08:49 PM   #4
afm199
afm199's Avatar
Mod Alumni
Founding Member
Top Percent Poster
No, the base circle goes about halfway around the cam and the clearance is the same the entire way. I check them up to almost 90 degrees.
Old 02-11-2019, 08:12 AM   #5
ctwo
Merely Rhetorical
ctwo's Avatar
Respectful Contributor
Motorcycles: motatoe
I think I measured a slight difference between lobes pointed away from stem and then at TDC. Maybe it's bike/cam specific?
ctwo is offline   Reply With Quote
Old 02-11-2019, 08:14 AM   #6
ichabodnt650
FZ-07
ichabodnt650's Avatar
Motorcycles: FZ-07, YW125
ichabodnt650 is offline   Reply With Quote
Old 02-11-2019, 08:26 AM   #7
afm199
afm199's Avatar
Mod Alumni
Founding Member
Top Percent Poster
The diagram above is a great illustration. The base circle goes way past 180 degrees.
Old 02-11-2019, 08:33 AM   #8
Junkie
re-tarded
Junkie's Avatar
Contributor + 3%
that's what I thought, just wanted to make sure.
the diagram above seems a bit off to me as far as the beginning/end of the lobe, but conceptually seems right
Old 02-11-2019, 08:39 AM   #9
Kalvin00
Kalvin00's Avatar
Motorcycles: 15 R1 + 16 Triumph Tiger 800XCA + 06SV650 Race
Yep. Although maybe it was just me but that engine won't turn over with the wheel. I always had to pop the cam chain cover and use a wrench.
Kalvin00 is offline   Reply With Quote
Old 02-11-2019, 08:42 AM   #10
Junkie
re-tarded
Junkie's Avatar
Contributor + 3%
did you pull the plugs?
Old 02-11-2019, 08:43 AM   #11
Kalvin00
Kalvin00's Avatar
Yep. Turns over fine with a wrench though.
Old 02-11-2019, 08:46 AM   #12
CrazyBiker
Rookie
CrazyBiker's Avatar
Motorcycles: 2016 Tuono Factory 2014 S1000R
Most manuals say that the cam lobes should be facing away from each other. Even if the manual doesn't mention it I would stick to TDC. I zip tie the cam chain to the sprockets to be sure.
I never have to pull the plugs but makes sense to release compression.
CrazyBiker is offline   Reply With Quote
Old 02-11-2019, 11:09 AM   #13
ctwo
Merely Rhetorical
ctwo's Avatar
It might turn easier in a higher gear?
Old 02-11-2019, 11:44 AM   #14
Smash Allen
a comedy of errors
Smash Allen's Avatar
AMA #: 3283336
Contributor ++
Motorcycles: S1000RR, FZ09, SV650, YZ250
Maybe if you are turning it with the rear wheel
Smash Allen is online now   Reply With Quote
Old 02-11-2019, 12:17 PM   #15
afm199
afm199's Avatar
Mod Alumni
Founding Member
Top Percent Poster
t
The step isn't there, but the numbers are right. Cam lobes don't go anywhere near the 180 line.
