Old 02-13-2019, 02:18 PM   #1
redruM
Peripheral Visionary
redruM's Avatar
Contributor +++++
Location: in a hologram, wrapped in a chimera and inserted into an illusion
Motorcycles: S1000XR / Dorsoduro 1200 / CB1000R
Fabbing custom metal parts for belly pan
Well, it's high time I put my barely mechanically-inclined brain to work and build something with my non-callused hands.
I want to mount a belly pan to my bike. If I go with all of the necessary OEM hardware, I'm looking at over $600 (thanks, Aprilia). I found the actual plastic fairing for cheap - but it's the special mounting bracket, nuts/bolts/spacers and special downpipe that I refuse to spring for. I may need to bite the bullet on the downpipe; won't go into all of it now.
Bottom line is, I want to make some custom aluminum parts that will enable me to bolt the fairing/pan directly to the engine case using whatever pre-existing screws I can. These can be crude parts, I don't care. They'll be hidden behind the fairing anyway. My question is, how do I go about it? Where do I get the materials? Make believe I'm an 8 year old.
redruM is offline   Reply With Quote
Old 02-13-2019, 02:43 PM   #2
Junkie
re-tarded
Junkie's Avatar
Contributor + 3%
What sort of tools do you have? Drill? Vise? Hacksaw?
You can buy metals online at places like mcmaster.com and 6061 aluminum is a decent option
if you need to attach threads to your object, I'd recommend a rivet nut kit (metric): https://www.ebay.com/itm/86pcs-Heavy...8L9u:rk:3:pf:0
for spacers, either use washers from your local hardware store or pick up some aluminum tubing of a reasonable ID/OD and cut it to length (for longer things)
Old 02-13-2019, 10:57 PM   #3
kuksul08
Suh Dude
kuksul08's Avatar
Motorcycles: Whee!
Go to home depot, buy some aluminum strip. Bend it over the edge of a table in to the shape you want. Drill some holes, bolt it on!
kuksul08 is offline   Reply With Quote
Old 02-14-2019, 08:51 AM   #4
295566
Five Apples
295566's Avatar
Contributor +
Motorcycles: 07 R1, 85 GPZ900R, 99 SV650 (track)
You'll end up with something like this:
295566 is offline   Reply With Quote
Old 02-14-2019, 10:10 AM   #5
redruM
redruM's Avatar
Contributor +++++
I have most of the tools - seems like it's gonna be a lot of trial and error, but we'll see.
That McMaster site is awesome! Hell, maybe all I need is an old Erector set.
Thanks gents.
Old 02-14-2019, 10:36 AM   #6
born2lse
Rookie
1% Contributor
Motorcycles: CB-1, F4I
You can use cardboard to get the general shape and dimension for the brackets. I usually pick up a 12 pack of beer and use the box from that. It's thin enough to approximate sheet metal.
Stainless steel brackets will generally be better than AL, depending on how thick the material and how heavy the belly pan is.
born2lse is offline   Reply With Quote
Old 02-15-2019, 11:02 AM   #7
ST Guy
ST Guy's Avatar
If you bend aluminum strip or sheet at a sharp angle, I can just about guarantee that at some point it will break at the bend. Use SS for anything that's going to be bent at a sharp angle.
Old 02-15-2019, 11:02 AM   #8
ST Guy
ST Guy's Avatar
This. Both for the cardboard trick and for the material.
Old 02-15-2019, 11:25 AM   #9
Junkie
re-tarded
Junkie's Avatar
Contributor + 3%
I disagree. My license plate mount (home made) is going strong after 5+y and it was just bent over the edge of a workbench.
Old 02-15-2019, 12:29 PM   #10
dravnx
dravnx's Avatar
AMA #3018349
Contributor +++++++
Barf Roadside Angel
Motorcycles: '12 DL650A '15 FJR1300A
Bending aluminum can be complicated. The bend radius is dependent on the thickness and type of material.
bike X miles=smiles
smiles ÷ bike=miles
miles ÷ smiles=bike.
It's simple math.
dravnx is offline   Reply With Quote
Old 02-15-2019, 12:47 PM   #11
ST Guy
ST Guy's Avatar
Depends upon the radius of the bend. Too small and the metal can be seriously compromised. Also depends upon the load the brackets will be carrying.
I learned the hard way and bent up some brackets for my horns on another bike and in short order, they broke resulting in one horn hanging down by it's wire and resting on the headers which then melted the horn body.
For what the OP is doing, the weight difference between SS and aluminum won't be much so I recommend SS. Much less chance of remaking parts.
Old 02-15-2019, 04:21 PM   #12
redruM
redruM's Avatar
Contributor +++++
I like the cardboard idea. I also like beer. Both should serve me well for this project.
The belly fairing weighs only a smidge over 1 lb.
Old 02-15-2019, 06:08 PM   #13
stangmx13
not Stan
stangmx13's Avatar
Contributor
BrotoGP
this thing?
youtu.be/qJ4CzgwdNPM
ya, I think u could make that huge bracket with a few pieces of flat stock from HomeDepot and some riv-nuts. u could prob get away with grommet nuts like for windscreens instead of riv-nuts.
Follow me on IG @rwpierce13
Thanks to: RiderzLaw Vortex
Old 02-17-2019, 08:46 PM   #14
kuksul08
Suh Dude
kuksul08's Avatar
Motorcycles: Whee!
If you just bend it once it will be fine. Besides it's just holding some fairings on, no biggie.
Old 02-17-2019, 09:53 PM   #15
ST Guy
ST Guy's Avatar
Once with aluminum, depending how it's bent, can be too much.
And if a fairing or belly pan comes off, it can be a hazard to the bikes rider and other riders, possibly causing some serious accident.
