BARF - Bay Area Riders Forum
Old 05-04-2018, 01:35 PM   #1
fortyonethirty
concussed
fortyonethirty's Avatar
Motorcycles: '12 kx450f
Buttonwillow, 13CW Riverside
I crashed during practice for the AFM round 2. I got knocked out for a couple minutes, so the whole thing is a bit fuzzy. I have some ideas on what happened, but I wouldn't mind a little BARF wisdom.
What do you guys think?
youtu.be//8d_fksc3Uaw
AFM #718
fortyonethirty is offline   Reply With Quote
Old 05-04-2018, 07:59 PM   #2
stangmx13
not Stan
stangmx13's Avatar
Contributor
BrotoGP
very hard to tell.
I wonder if u chattered the front end. for about 1sec before u actually crash, theres a fluttering noise and some extra shaking on the video. also, the black line that goes by looks to be rubber not a seam. its a broken line, implying the tire was bouncing. do u know what chatter feels like?
did u brake at all? if I get in really hot into that corner, I make sure to brake a little bit to load the front end and tighten my turning radius.
Follow me on IG @rwpierce13
Thanks to: RiderzLaw Vortex
stangmx13 is online now   Reply With Quote
Old 05-04-2018, 09:19 PM   #3
Slow Goat
Fun Junkie
Slow Goat's Avatar
Motorcycles: Make me feel better about life...
Looks like the front tire left a skid mark as it was going down.
Hope you’re okay.
Slow Goat is offline   Reply With Quote
Old 05-08-2018, 07:16 AM   #4
afm199
afm199's Avatar
Mod Alumni
Founding Member
Top Percent Poster
Originally Posted by stangmx13 View Post
very hard to tell.
I'm with this. I just had the same front chatter yesterday at Sears Point, woke me right up.
Old 05-08-2018, 02:55 PM   #5
tzrider
Write Only User
tzrider's Avatar
BARF Admin
Contributor +
Motorcycles: Kaw N1K
You were on the gas then closed the throttle about a second before crashing. From the available info, it's likely you overloaded the front.
It may be that simple, though could have been exacerbated by having had pressure on the bars. We can't tell about that from the video; only you might know whether or not that was a factor. Being off the throttle, it's more likely than not.
Old 07-18-2018, 10:31 PM   #6
viva_brasil
viva_brasil's Avatar
Contributor +++++++++++++++
Motorcycles: EBR 1190RX, 999, R1
what would cause the chatter in this case?
Isn't chatter usually caused by bottoming out the forks - so corner speed + closing throttle + potentially weight on the bars = bottom out and chatter?
Instagram
Builds:
MonsterStrada
999S
Honda VTR1000F
2VSBK
798S
viva_brasil is offline   Reply With Quote
Old 07-19-2018, 07:04 AM   #7
stangmx13
not Stan
stangmx13's Avatar
Contributor
BrotoGP
Chances the OP bottomed the front end into Riverside are slim to none. And, bottoming out doesn’t necessarily cause chatter. Chatter is an uncontrolled oscillation where some disturbance creates a feedback loop that leads to all that. Well it can be that. It’s so complicated that it’s hard to nail down w specifics. Nearly anything with a bikes setup can be the cause and fix for chatter issues: springrate, tire pressure, ride height, etc.
Old 07-19-2018, 08:09 AM   #8
Smash Allen
a comedy of errors
Smash Allen's Avatar
AMA #: 3283336
Contributor ++
Motorcycles: S1000RR, FZ09, SV650, YZ250
could a bad tire cause chatter?
Smash Allen is offline   Reply With Quote
Old 07-19-2018, 12:20 PM   #9
tzrider
Write Only User
tzrider's Avatar
BARF Admin
Contributor +
It could, though if this rider had several laps on the tire already without feeling chatter, that's probably not it, unless something physically failed.
Old 07-21-2018, 09:57 PM   #10
BabyRider
Newbie
Motorcycles: Ninja 300
it could have been the tire was starting to blister?
BabyRider is offline   Reply With Quote
Old 07-21-2018, 10:49 PM   #11
tzrider
Write Only User
tzrider's Avatar
BARF Admin
Contributor +
Given that we can observe riding errors, let’s use Occam’s Razor.
Old 07-23-2018, 10:20 AM   #12
viva_brasil
I understood "chatter" was the tire slipping slightly and re-gripping in fast succession (i.e., the fork is unable to absorb / control the forces on the tire, including a bottomed out fork or too much rebound potentially, etc.)?
Sounds like that's not right, so just trying to understand what it is... "Uncontrolled oscillation" of what?
Instagram
Builds:
MonsterStrada
999S
Honda VTR1000F
2VSBK
798S
Old 07-23-2018, 02:20 PM   #13
stangmx13
not Stan
stangmx13's Avatar
Contributor
BrotoGP
What riding errors do u see?
Closing the throttle there is correct. If anything, it was closed too soon. Perhaps it was closed too fast.
Old 07-23-2018, 02:22 PM   #14
stangmx13
not Stan
stangmx13's Avatar
Contributor
BrotoGP
The forks moving up and down in very fast succession is the chatter part, is the uncontrolled oscillation. But of course u can have chatter at the rear too. Uncontrolled == unstable == does not decrease in magnitude over time. Oscillation == cyclic movement. A tire slipping and regripping could cause chatter, or chatter can cause that.
Old 07-23-2018, 04:08 PM   #15
Smash Allen
a comedy of errors
AMA #: 3283336
Contributor ++
i was pitted with ian in the garage
he was on bridgestones, we (not ian, he was loopy all day after that) were thinking at the time it was a bad front tire
if not the tire, i would be interested to find out the condition of the suspension / suspension fluid
it reminds me of a tank slapper, but going 'up and down' instead of 'side to side'
