BARF - Bay Area Riders Forum
Go Back   BARF - Bay Area Riders Forum > Club House > Reviews & Recommendations
Old 10-10-2018, 08:40 AM   #1
senpai71
Professional troublemaker
senpai71's Avatar
Motorcycles: 2015 Kawasaki Versys 1000LT, 2000 Triumph Sprint ST
Chinese aftermarket levers - as deadly as some people say?
Hey folks,
Has anyone had any GOOD experiences with the cheap Chinese aftermarket brake/clutch levers you find on EBay?
I'm trying to find OEM replacements for my 2000 Triumph Sprint ST, and they're hard to find and hella expensive. Or maybe I could get some high-end aftermarket ones (ASV or Pazzo, perhaps?) but again - pricey for a bike which is old and isn't even worth that much any more.
The ones on EBay are cheap, but many of the reviews you see out there say they're deadly. But then, that's because I'm searching for "aftermarket chinese brake levers motorcycle" which probably won't surface many positive reviews anyway...
Thoughts?
Sometimes bad things happen to good people. And vice-versa...
senpai71 is offline   Reply With Quote
Old 10-10-2018, 08:48 AM   #2
lost.in.cali.
Rookie
lost.in.cali.'s Avatar
Motorcycles: cb500f
I bought these in 2015. have been great after 20k miles
https://www.amazon.com/CTG-CH-077-Ad...r7L&ref=plSrch
#FreeKekistan
lost.in.cali. is offline   Reply With Quote
Old 10-10-2018, 08:58 AM   #3
Junkie
gone for now
Contributor + 3%
Motorcycles: n/a
I've had good experiences, but I'd be hesitant to run one on the brake side (clutch it's less likely to cause an injury)
Old 10-10-2018, 09:01 AM   #4
Maddevill
KNGKAW
Maddevill's Avatar
AMA #: 542337
Motorcycles: ZX14,GS750E, RM250
I have used Chinese lever sets on my last 3 bikes with absolutely no problems at all. My current ones fold up in crashes, look great and I think are great value. A precaution though, on my friend's rear sets, we had to Locktite every bolt or they would fall out.
Mad
Old 10-10-2018, 09:03 AM   #5
Maddevill
KNGKAW
Maddevill's Avatar
AMA #: 542337
There have been reports of brake levers that had the brake master cylinder plunger shaft drilled too shallow. This caused the brakes to drag and overheat. The fix was drilling the hole deeper. Keep that in mind.
Chinese products get better every year. They even make the new Benelli bikes now.
Mad
Old 10-11-2018, 07:36 AM   #6
Starpower
Starpower's Avatar
12% Contributor
Motorcycles: '14 BMW S1000R, '13 Zero S, '01 Artic Cat 500 4x4 '09 KTM SX-F 250 '82 XT250
The last 3 sets I had were flawless. 2 of them had a better fit than OEM.
Starpower is offline   Reply With Quote
Old 10-19-2018, 01:08 PM   #7
senpai71
senpai71's Avatar
Well, I bought some, so I guess I'll find out. I just can't justify the cost of pricey levers on this cheap bike.
Old 10-19-2018, 01:12 PM   #8
Tally Whacker
Tally Whacker's Avatar
Motorcycles: BMW S1000R
I've had them on my last two bikes, aver 80,000 miles with no problems at all other than anodizing fade.
Tally Whacker is offline   Reply With Quote
Old 10-19-2018, 04:47 PM   #9
dravnx
dravnx's Avatar
AMA #3018349
Contributor +++++++
Barf Roadside Angel
Motorcycles: '12 DL650A '15 FJR1300A
Prolly have 80,000 miles on a set, clutch and brake, on my Vstrom. Bought them on Ebay. The forum wags said I would die in a flaming ball of melted plastic and metal if I used them.
bike X miles=smiles
smiles ÷ bike=miles
miles ÷ smiles=bike.
It's simple math.
dravnx is online now   Reply With Quote
Old 10-20-2018, 11:39 AM   #10
HadesOmega
HadesOmega's Avatar
Barfie Winner 2017
Motorcycles: Empulse TT, ZR7, DR650, KLR650, 750 Turbo, Light Bee MX, KLX140L
Been running an ebay set on my ZR7 and Empulse for a while now. They seem fine. One of them had a problem staying on one of the adjustment detents, it would slip but doesn't do it anymore must've worn the detent in so it locks better.
HadesOmega is offline   Reply With Quote
Old 10-20-2018, 01:00 PM   #11
doc4216
Coastie who high fives
doc4216's Avatar
AMA #3289553
Contributor + + + + +
Motorcycles: 2016 R1200RS
Bought them for my VFR, no issues and felt great.
A straight road never made a skilled rider.
doc4216 is offline   Reply With Quote
Old 11-01-2018, 01:55 PM   #12
somesuch
Motorcycles: gsxr
Speed Metal Cycle Gear levers
I had a cheap set of levers from Cycle Gear (Speed Metal) that looked like a re-packaged Ebay levers. The fit was OK on the clutch side, but the brake side I had to file a bit so that the return port was not blocked by the lever pre-loading the piston (I did a stoppie on Winchester and Stevens Creek, had someone help me drag the bike to the curb as the front brakes were locked - lucky!). After a couple of months of use, one of the roll-a-click bearings broke apart, and Cycle Gear exchanged it (with some resistance). Used that bike for just another 1K miles or so, and sold it, so don't know how well the replacement one lasted.
CRG levers on another bike were absolutely flawless lasting many miles, surviving crashes, end delivering enjoyment
The CRG levers felt better too, and did not have the sharp corner of Speed Metal that ate through the pair of gloves I had.
somesuch is offline   Reply With Quote
Old 11-01-2018, 04:29 PM   #13
PorradaVFR
The Temptations of Christ
PorradaVFR's Avatar
Motorcycles: 2004 Honda VFR 800A, 2008 Ducati Hypermotard S (sold), 2004 Honda VFR 800 (RIP) :(
I’ve had three sets of the eBay alternatives. The first were slightly long which resulted in a “click” when they would hit the bar end, even when adjusted outwards. Gave those to a friend. The second set were great - but the red bit faded and I didn’t like that look so I got a monochrome set I use to this day. Hard braking, no problem and no issues - I do lubricate the roller pin now and then as you should anyway.
"Mgrush Fernran Grrable Mrgsush" - RRITTERSON
"I don't think anyone should ever take my advice." - KILLAKEYES
Witty comment. [citation needed]
PorradaVFR is offline   Reply With Quote
Old 11-02-2018, 11:48 AM   #14
newbiker
newbiker's Avatar
Motorcycles: 2016 Ninja Zx6r
That's usually the advise you get from people who don't think out of the box. The world has evolved a lot!
Good for you!
Great - and where can I get these for my new ZX6r, looking for adjustable for track use and daily commute/etc.
newbiker is offline   Reply With Quote
Old 11-02-2018, 01:36 PM   #15
Biga
Near Miss Racing #96
Biga's Avatar
Motorcycles: 250 Ninja "A" R3 600 GSXR TS 185 150 Scooter 97cc D. Bug
Same here!!! But after trying many different ones I found the OEM's are best. Better feel to it... and cheap...
CMRA# 672
Biga is offline   Reply With Quote
