BARF - Bay Area Riders Forum
Go Back   BARF - Bay Area Riders Forum > Moto > Riding Skills
Old 01-06-2019, 06:18 AM   #1
chukwu
Newbie
Motorcycles: Ninja 250 2009
Riding loose
Ok, Im a new rider I started nov I took the training course and all that jazz. lately, I realized I've been riding really tight because I could feel the bump of the road and driving over 25 feels like im moving at the speed of light. Now that im thinking about how I ride it's a bit awkward holding my handlebars it's there a trick to forcing myself to hold it correctly I heard of the Swervedriver thing but I don't understand
chukwu is offline   Reply With Quote
Old 01-06-2019, 09:39 AM   #2
Butch
poseur
Butch's Avatar
AMA #: 1093637
BARF Moderator
Founding Member
BARFie winner 2014 & 2017
Contributor +++
Barf Dirtbike Political Advocate
Motorcycles: ‘18 Alta EX006, ‘17 Alta MX019, 06R6, 05TM503 Black Dream, 01TM250 2T, 91ATK406
Some folks grip the tank with their knees.
My style is weight on the pegs and a firm grip on the bars, but otherwise I let the bike move around a bit, with my ass lightly on the seat.
This is in the twisties. No comment in slabbing. I suppose if I had to ride in traffic much weight would on the pegs as I maintain vigilance.
I stand almost 100% when riding a dirtbike. And my ‘tard.
Butch
Hodaka Ace 90. I've been riding these things too long. What can I say? How about that Combat Wombat?
Terms of Service:
http://www.bayarearidersforum.com/info/tos.php
and get a dirtbike! preferably a 2 stroke... Or... Electric!
Butch is offline   Reply With Quote
Old 01-06-2019, 11:53 AM   #3
stangmx13
not Stan
stangmx13's Avatar
Contributor
BrotoGP
if 25+ feels like the speed of light, I bet most of your issue is in your head. overly stressing, freaking out, or being anxious or nervous can easily increase your sensation of speed and make it very difficult to ride well. and of course, u cant expect your body to be relaxed and loose if your mind isnt as well.
as for grip, everyone has their own style so its hard to recommend something specific. just make sure you don't lock your elbows or wrists and you've adjusted your levers. the screwdriver method is mostly for hanging off really far and track use. so it prob doesnt apply to u now.
some awkwardness in trying to ride loose probably comes from how hard u are holding on. if u are gripping tightly to actually hold yourself on to the bike, u probably need to support your weight another way as Butch suggested. using your legs and core are the best ways to take weight off your hands. however, if you are gripping tightly because u are stressed, that goes back to my first point.
Follow me on IG @rwpierce13
Thanks to: RiderzLaw Vortex
Old 01-06-2019, 12:13 PM   #4
Gary856
Are we having fun yet?
Gary856's Avatar
Motorcycles: WR250F, 690SM, SD990, R1200GS, MTS1200, 950SM
Riding loose for beginners means loosening your grips, bending your elbows, crouching your upper body slightly to absorb the bike's movements and impacts, sort of rolling with the punches. If you're about to hit a hard dip or a pothole, rising up slightly from your seat and using your knees/legs to absorb some of the impact, allowing the bike to bounce and jiggle without adding unneeded input from your uncontrolled weight transferring into the handlebars.
Holding the throttle like a screwdriver to me means when you're in a hard left turn, with the left grip forward and the right grip very close to your body so your right arm would be crowding against your body if you kept your grip perpendicular to the throttle. Instead, you'd angle your grip to hold the throttle like how you'd hold a screwdriver (or a stick or a flashlight) pointing toward your 10 o'clock. People use "screwdriver" to describe this grip angle since you twist the throttle like you would with a screwdriver.
Gary856 is offline   Reply With Quote
Old 01-06-2019, 02:09 PM   #5
Enchanter
Ghost in The Machine
Enchanter's Avatar
AMA #: 2815246
BARF Admin
Founding Member
Barfie Winner 2007, 2010, 2014, 2017
Contributor ++++++++++
Motorcycles: Attack™-ed R1 & hybrid S1000rr
A tight grip / tense muscles is usually a symptom of a different issue rather than the actual problem itself.
For new riders, this is almost always caused by the failure to look farther / far enough ahead. The sensation of (high) speed will diminish if you get your head and eyes up and look at the horizon and not down at the road surface. Once it appears that you aren't speeding, you will likely relax your grip and stress level will drop too.
Another thing I have seen is newer riders concentrating on their actual speed, i.e. looking at the speedometer. If you are doing that, a temporary trick to that is to put some tape over it so that you cannot see the actual speed.
A superior rider uses superior judgment to avoid situations that require superior skill.
Originally Posted by DataDan View Post
Be resilient. After an unpleasant surprise or close call, get your head back in the game quickly. Learn whatever lesson you can and move on.
Originally Posted by cardinal03 View Post
The panties. Unbunch them.
Occam's Razor: The simplest explanation tends to be the right one.
Hanlon's Razor: Never attribute to malice that which is adequately explained by stupidity.
BARF Terms of Service
Enchanter is offline   Reply With Quote
Old 01-06-2019, 09:23 PM   #6
chukwu
Newbie
Damn thanks for the advice there all great. I need to work on holding the bike with other parts other than my hands or legs and thighs... and looking ahead yea I look at the speed thermometer a lot so I need to tape that (that's a bit scary). ok, im going to read the thread every day and practice once the roads aren't wet anymore.
Old 01-07-2019, 07:15 AM   #7
Underdog
Prehistoric
Underdog's Avatar
1% Contributor
Motorcycles: '16 WR250R (3k) '14 Ninja1K (60k) '07 FJR1300A (93k)
Remember to breath. Bend your elbows.
Underdog is offline   Reply With Quote
Old 01-07-2019, 07:48 AM   #8
Maddevill
KNGKAW
Maddevill's Avatar
AMA #: 542337
Motorcycles: ZX14,GS750E, RM250
Re read what Enchanter said. 100% correct. When you're a new rider you tend to look right in front of the bike. This gives your brain no time to take in all the info sent from the eyes. If you have a High Visual Horizon, you give yourself more time to absorb the info. A High Horizon operates almost like looking into the future. The farther you look ahead, the more time you give yourself to absorb and adapt.
Mad
Old 01-07-2019, 10:36 AM   #9
motomania2007
MSF/MTC CMSP Instructor
Motorcycles: BMW R1200R, FZ09, FZR400, CR250R
What Enchanter said is spot on!
If you need help with that, I suggest taking the Intermediate Riding Clinic at one of your local CMSP training ranges. This is one of the main things taught in the IRC and it helps newish and not so newish riders tackle this issue.
If you are not having fun riding a motorcycle, you are doing it wrong.
<stands, raises hand> Hello, my name is George and I am a motorcycle addict!
Please come to one of my MSF, Total Control or CMSP classes and allow me to share my addiction with you.
Total Control MTC, IRC and ARC instructor
http://www.valleymotorcycletraining.com/signup.html
The best performance upgrade is upgrading the operating system of the operator. It is cheap, easy, fast, safe and works on every bike you will ever ride.
I am also a Patent Attorney so if I can help you with any IP matters, please just ask.
motomania2007 is offline   Reply With Quote
Old 01-07-2019, 11:03 AM   #10
Junkie
gone for now
Contributor + 3%
Motorcycles: n/a
Sounds like you need to have a few beers to relax
How much have you ridden so far?
I agree with other people that looking farther ahead is a good idea.
It sounds to me like he isn't ready for IRC yet
Old 01-07-2019, 11:40 AM   #11
budman
General Menace
budman's Avatar
AMA Life Member #203453
Highway Aviator
Founding Member
Top Percent Poster
Community Contributor + BB
Moto Junkie
Motorcycles: A few here and there
I agree.. good advice above. Eyes up!!
I will add...are you wearing earplugs?? Wind noise getting baffled down helps you focus and takes away some of that feeling of ludicrous speed.
budman is offline   Reply With Quote
Old 01-07-2019, 02:11 PM   #12
stangmx13
not Stan
stangmx13's Avatar
Contributor
BrotoGP
thats a good point. I accidentally did a sighting lap on track without earplugs. holy fuck it was loud and felt really fast. it was also impossible to concentrate with that extra sensory input.
Old 01-07-2019, 02:17 PM   #13
ScottRNelson
Mr. Dual Sport Rider
ScottRNelson's Avatar
Founding Member
Contributor
Motorcycles: Honda XR650L, KTM 1090 Adv R
Something I've read in multiple places is to occasionally flap your elbows as if they were wings or something to make sure you're keeping your arms loose. I still occasionally tighten up for some reason and as soon as I notice it I start flapping my arms as a reminder. How tightly hour hands are holding the grips is an independent issue.
Scott R. Nelson - Meridian, Idaho
ScottRNelson is offline   Reply With Quote
Old 01-07-2019, 04:03 PM   #14
HadesOmega
HadesOmega's Avatar
Barfie Winner 2017
Motorcycles: Empulse TT, ZR7, DR650, KLR650, 750 Turbo, Light Bee MX, KLX140L
Rawhyde Adventure had a little seminar at SJ BMW and they mentioned that you want to be tense on the motorcycle because if you hit a bump or something you are more likely to loose control of the bike because you will jerk the bike where your body is moving. If you are loose your body will kind of absorb the impact rather than trying to counteract it and the bike will stay on course. He even demonstrated this on a R1200GS inside that wasn't on.
Also I am guilty of being a white knuckle rider. If you are tense you will tire yourself out also.
HadesOmega is offline   Reply With Quote
Old 01-07-2019, 10:05 PM   #15
motomania2007
I agree with other people that looking farther ahead is a good idea.It sounds to me like he isn't ready for IRC yet
The IRC can be used very early. One version of the IRC is day 3 of the MTC.
