BARF - Bay Area Riders Forum
Old 03-15-2019, 09:55 AM   #1
jy116
live+learn
jy116's Avatar
Motorcycles: 2007 FZ6
Low Side by Oakland Airport
Sup BARF! I had an upper-fairing-smashing low side recently coming from hegenberger/98th to Ron Cowan. I was fine on the right turn sweeper, then as I transitioned to turn left, I lost traction and low sided at a speed a little higher than the posted 45mph limit. It happened so fast I couldn't even think of correcting before my hip slapped the ground and I was sliding in my back watching my bike slide away. I had only been riding about 10min mostly in a straight line, so I think the tires were cold and I was just going too fast, not smooth, road cold, maybe gritty. How long is a proper warm up for Dunlop Q3s?
Do you think an inline 4 is more prone to low side vs a twin? Not blaming the bike, but considering a switch to help my hip (this if my second low side, first one was much slower, very minor slide, but big bruise on same left lower hip bone). From this spill, I got a scrape on my calf about 3x5 inches, just the top layer because my riding jeans helped I guess! I just wish there was a pocket for hip protection (Street and Steel Oakland jeans)... Anyone interested in the road rash healing tips I found? WebMD FTW!
"Listen to advice and accept instruction, that you may gain wisdom in the future" Proverbs 19:20 (ESV)
jy116 is offline   Reply With Quote
Old 03-15-2019, 10:03 AM   #2
Junkie
gone for now
Contributor + 3%
Motorcycles: n/a
Did you lose the front or the rear?
Old 03-15-2019, 10:23 AM   #3
jy116
live+learn
jy116's Avatar
Must have been front because I didn't feel the back come out or bike rotate. I had just began the transition from right lean to upright and left
Old 03-15-2019, 10:26 AM   #4
jy116
live+learn
jy116's Avatar
Arial view of the road and pin where I lost it
https://photos.app.goo.gl/bccuQVmpFwueNLsx9
Old 03-15-2019, 11:32 AM   #5
Maddevill
KNGKAW
Maddevill's Avatar
AMA #: 542337
Motorcycles: ZX14,GS750E, RM250
Might have been some antifreeze or diesel fuel on the ground. Hard to see.
Mad
Old 03-15-2019, 11:49 AM   #6
cal scott
Wookie
cal scott's Avatar
Motorcycles: V-Strom DL650AL3
If you haven't found it yet, 3M Tegaderm is the answer to road rash. Amazing stuff. Not cheap but you can leave it on for up to 7 days (survives showering-I've even been in a hot tub with it on). It is a transparent membrane that let's the skin breath but prevents any fluid escaping or bacteria invading. Wound doesn't scab up so the risk of scarring is greatly reduced. You can literally watch it heal through the membrane. For rash larger than the 4" x 4" size, multiple membrane's can be overlapped. Just make sure you scrub the wound well before applying as any bacteria left will be sealed into a perfect environment for growth.
To those dead souls inching along the freeways in their metal coffins,...
..we show them that the human spirit is still alive.
-- Point Break
cal scott is offline   Reply With Quote
Old 03-15-2019, 11:49 AM   #7
ScottRNelson
Mr. Dual Sport Rider
ScottRNelson's Avatar
Founding Member
Contributor
Motorcycles: Honda XR650L, KTM 1090 Adv R
Yet another reason why I prefer sport touring tires to pure sport tires. They still have most of the grip when they're cold.
Scott R. Nelson - Meridian, Idaho
ScottRNelson is offline   Reply With Quote
Old 03-15-2019, 01:12 PM   #8
berth
berth's Avatar
Motorcycles: KRS-1200
Nominally, a twins power hits the drive train "harder" (2 big hits vs 4 smaller ones), but that's not universal, and likely not a problem.
Neither is a problem if the gas thingy isn't twisted too far.
#69 #45
berth is offline   Reply With Quote
Old 03-16-2019, 07:43 AM   #9
danate
#hot4beks
danate's Avatar
AMA #: 2948810
Contributor + + + + 3%
Motorcycles: Big pompous Beemers
This. Sport touring tires are truly the best for street riding. It's hard to say why you went down, though, if you are not sure exactly what you were doing when it happened. Common problems in turns are adding gas as you add lean angle or rolling off/decelerating as you turn in.
Also, riding jeans rarely provide adequate protection for a crash. Get some real protective pants with good hip protection. I'm personally a fan of Motoport as it provides a lot of padding over the hips and legs (though I also use Aerostich and love it). Also, leathers, of course, provide good protection.
danate is offline   Reply With Quote
Old 03-16-2019, 07:52 AM   #10
EastBayDave
- Kawasaki Fanatic -
EastBayDave's Avatar
Founding Member
From the heart
Motorcycles: ZRX1200
cold tires? Quite possibly.
more likely you hit some fluid spill from a vehicle; oil, antifreeze, grease, etc. is all over the place.
what were the conditions at the time? (temp/weather)
Enjoy the ride!
EastBayDave is offline   Reply With Quote
Old 03-16-2019, 08:12 AM   #11
kneedraggeroldy
Rookie
kneedraggeroldy's Avatar
Motorcycles: FJR1300 R6 KLX300R
Whoa....been riding decades and never knew this stuff existed! Thanks for info. Sorry to hear about the low side....agree hard to see but something on road can cause rapid in ohs as did something similar long time ago with oil in a set corner
kneedraggeroldy is offline   Reply With Quote
Old 03-16-2019, 08:47 AM   #12
Gary856
Are we having fun yet?
Gary856's Avatar
Motorcycles: WR250F, 690SM, SD990, R1200GS, MTS1200, 950SM
This crash analysis forum has really gone downhill.
Debris, fluid, sharp objects, bubble gum - those are your guesses, not analysis.
Sport touring tires are best - that's your preference, not analysis.
Cold tire - can we not perpetuate this as a cover up for rider error? You expect wire warmers for street riding?
Tegaderm - yes, that stuff is awesome!
Inline 4 more prone to low-side compared to a twin? They tend to have different power delivery characteristics which may affect traction when you ride at the limit, but one is not better or worse for normal, everyday use.
Some typical info that are needed for analysis:
- What time of the day was that? Light level? Visibility? Temp?
- Dry or wet road?
- What was your rpm?
- Were you accelerating, cruising, coasting, or braking?
- How hard were you on the throttle or brake?
- How hard/sharp was your transitioning to turn left?
- Are you familiar with this route - ride it routinely?
- Did you scan the road surface for anything unusual?
- Where were you looking at the time?
- How was your condition at the time - fresh and alert, or tired and distracted?
- What was the traffic condition?
- How often do you ride? Your weekly mileage?
- How do you describe your riding experience and skills level? Do you only commute or ride in the hills much?
- Tire mileage/condition?
- Front/rear pressure?
(At least we know what OP's bike/tire are, unlike the guy asking about tire mileage/wear but wouldn't even share what bike/tire he's riding. )
Gary856 is offline   Reply With Quote
Old 03-16-2019, 10:33 AM   #13
ScottRNelson
Founding Member
Contributor
- Dry or wet road?
- Were you accelerating, causing, coasting, or braking?
- Where were you looking the time?
This list of questions should maybe go in a sticky at the top of this sub-forum. It would be much easier to analyze a crash with this information.
jy116, can you answer all of these?
As for the paragraph right above this part, a V-twin is definitely better for normal, everyday use.
Old 03-16-2019, 02:15 PM   #14
Saxon
Newbie
Motorcycles: triumph, suzuki
Excellent analysis questions!
Saxon is offline   Reply With Quote
Old 03-17-2019, 09:30 PM   #15
tzrider
Write Only User
tzrider's Avatar
BARF Admin
Contributor +
Motorcycles: Kaw N1K
The questions are very good, though in this case you might not need the answer to all of them. From what we know so far, I’d say the most important questions will concern which other controls the rider was using while steering the bike:
We’re you on the gas? If so, what were you doing with the control right then?
We’re you on either brake? If so, how much? Adding pressure, holding steady or taking away?
