Snaggy
Will try to provide answers to clinical concerns.
I’m an Internal Medicine doc, practicing Urgent Care exclusively the last 2 years.
With the new antibody test coming to determine ones exposure / immunity, I have a few questions.
1. Can one be naturally immune even though one was never exposed ?
(I know with HIV they found that 22 African prostitutes carried full natural
Immunity against AIDS ; Is this possible with SARS / COVID viruses as well ?)
2. Will they use blood of those immune to help others as a “natural vaccine ?”
3. If I give blood now , will they run this immunity test or test at all before draw? If not, is the blood good if one has COVID 19 or is it solely isolated in the respiratory system?
4. How does Hydroxychloroquine potentially work to combat or lessen this virus ?
Does it have to be “loaded “ in ones system prior to exposure like in Lupus patients or can it be used once exposed ? And for how long ?
Finally , 5. are all Quinolines potentially of benefit or effective? ( Such as Mefloquine ?)
can a mask be cleaned by using microwave steam?
No, they will NOT run a CV antibody test with a blood donation. They won't. They won't test you for CV infection either. They will exclude you for respiratory symptoms, maybe check a temp.
Many of them have a metal strip over the nose or a clip on the strap. Nuke it with care. A variety of cleaning techniques have been proposed. Isopropyl dunks have been tried.
The studies which performed actual virologic and fit testing afterwards are beyond the home user, though I guess you could wrap one in a paper bag and Insta-Pot it for 12 minutes, then dry. That approximates an autoclave.
The CDC recommends what I'm doing. I have a half dozen N95's. I wear one for a few hours, then hang it up, not touching anything and let it dry for 24 hours, at least. Drying destroys the virus and it happens fairly quickly on porous surfaces. Who knows?
Is it true that a CPAP machine can substitute for a ventilator in a pinch?
Dr Fauci was on PBS Friday evening and said that in the real world (not the lab) the virus can infect you from a surface for 2 or maybe 3 hours. After that the virus has degraded to a point that it lacks sufficient ________, ( I think he said rigor but I am not sure. Would you know what ________ is?
Thanks
When referring to clinical studies, "rigor" means a tight study, good methodology, good controls, good data, lots of subjects, high statistical significance.
He's saying the evidence isn't great, but...
Medical question: Is it likely cough syrup might relieve the dry cough when someone catches this thing?
Thanks for your response. Just one more question. Does what DR Fauci said mean that if I go to bed for 8 hours when I wake I don't need to be worried about contracting the virus from objects in my house because the virus has degraded?
Thanks
Whenever I have had the flu or a bad cold, I always felt better after taking a hot shower and eating spicy soup.
Would you agree that this a regimen to take for Covid-19 patients and anyone with flu-like symptoms, taking hot showers to help dislodge phlegm from lungs and spicy soup to open sinus cavities?
I think Dr Fauci would lapse into DocTalk and say, "yes we think it's probably safe. Most likely".
First, as Dr SLO said, theoretically the risk is never zero, and the idea is the virus has been destroyed logarithmically until the remainder is no longer likely to cause infections. I don't think "rigorous studies" indicating that number for CV19 exist yet, though other Corona viruses have been studied and are used for inference. Also the surface matters. The virus is relatively stable in liquid suspension, so a moist surface would be less safe. A porous surface would dessicate the virus, damage the lipid envelope it picked up from the cell it destroyed, and inactivate it.
I am using a commercial quaternary ammonium salt cleaner, either as a wipe or as a spray, on the counters, door knobs, keys, phone, wallet, fridge and that stuff 2 or 3 times a day at home. Eyeglasses, I'm using an Isopropyl spray. At work, I'm wiping keyboards, mice, my badge/RF ID etc too. I'm using soap on my hands and surfaces liberally.
Yikes! So, if you need blood you may get blood from a person with CV that is asymptomatic? I would guess that getting CV blood would also infect you, but perhaps CV is more in the lungs and infects the lungs.
Doesn't drinking a lot of fluids help your cells to transport a bunch of the byproducts of virus' attack on your cells through your blood stream into your kidneys and and into your urine?The virus actually targets receptors on the cells lining blood vessels. The lung tissues happen to have a lot of those receptors and are an easy door to kick in. It's damage to the small vessels that destroys the integrity of the cellular barrier that keeps the plasma from leaving the circulatory system. It leaks into the alveoli/air sacs, where it inhibits oxygen diffusion and blocks small airways. Those secretions are expelled in cough, a diabolically efficient way to spread virus. Perfect little bastards, viruses.
I would not want to get a blood transfusion right now. It's one of several reasons to avoid surgery now, go easy on the bike and generally don't get hurt.
I know that lots of fluids helped to significantly improved the chances of surviving ebola.
I feel denatured is a broad satement. Do you know what it was denatured with?
The FDA requires hand sanitizer manufacturers to denature their end product. ie, put shit in it that will make you sick so you don't drink it to get drunk. It's why you can't use denatured alcohol to clean electronics, it leaves a residue behind.
https://www.fda.gov/media/136390/download
Unless you know what process your bottle went through, it would be hard to say.
