pho iz good
So I just got back home from the 1st day on the range of the msf course. everything was going well for me, I had no trouble find the friction point, I start off in 1st gear smoothly, didnt die out anytime, went around the curve smoothly, except for 1 thing....the last exercise...."Quick Stop"
So I thought to myself..oh sounds easy...but boy was I WRONG. Its the exercise where the instructors stands in front of u about 40 yards away and when she gives you the stop signal, you stop immediately....using the front brakes, rear brakes, clutch in and downshift into 1st all at the same time.
First attempt....low and behold...I lock the front brakes.. and I hurted my ass REAL BAD on that attempt...its ok, i recover and suck up the pain and try again..
second attempt....I did everything OK except I was going to slow the instructor said...
3rd attempt... It took me to long to do a quick stop..(i was suppose to stop within half the distance I attempted) instructor was really cool about it because she said I was still scared from the first attempt and that I shouldnt be scared of the front brakes anymore.
4th attempt..... same thing....I took too much distance and didnt stop "quickly", then she told me that this will be on the test tomorow and that it was important for me to do this correctly...
5th attempt.... I did everything WELL except....while IM braking...Im also revving the engine...with the clutch disengaged of course.
6th attempt.... same as the 5th attempt....
I need help and tips you guys...I cant seem to stop quickly enough and after locking up the front brakes... the coach said I cant be scared of it no more and that I need to trust it again...
Hypothetically speaking...if I failed to stop quickly, will I fail the whole course or is this only 5 points deduction from the test or something? thanks you guys.
