Z3n
Squid.
Starting to document my builds more directly, so figured I'd spin up a thread here.
I've got a couple of things in the pipeline right now, so expect updates in the short term on my RC890 project (or as I lovingly refer to it, the wish.com RC8C):
Waiting for an exhaust from HP Corse, and some titanium from TiCon to start on it.
I've also got an electric enduro I'm in the process of building, retaining the clutch, transmission, and original crank. I've been through a few iterations in different frames, but the right call here ended up being converting my 2011 KTM 300 XC.
Today I finally had the time and motivation to tear down the dirtbike:
And drop the bottom end into the bike:
I've got the rough mounting locations figured out:
Next steps: Split the cases, remove the conrod, weld up the crank so it can't rotate around itself, balance it to minimize vibration, weld a sprocket mount to the rotor (or just lazyweb and weld the sprocket directly), build the motor mounts and battery box. Then find a location for the controller, wire everything up, and it should be ready to go.
As to why I'm going through all this work, well:
1. The Brammo Empulse R taught me that a transmission on an electric bike actually rules. Having quick acceleration at low speeds and a high top speed is good! You don't need as many gears on an electric - a 3 speed would probably be fine, maybe 4, but a gearbox gives back much more in usable acceleration than it costs you. This goes double when you can run the motor in higher efficiency ranges because RPM isn't strictly linked to road speed. In the early days of cars, we compensated for a lack of transmission gears and quality with bigger motors, but packaging and motor availability is a problem on bikes.
2. A clutch and flywheel is critical for managing rapidly variable traction and aggressive power delivery. If you're on a motocross track that is groomed and has relatively consistent traction, you don't give up much. But for hard enduro, trials, and getting the most power to the ground when you need it, you can't ride the same way if you don't have a clutch/flywheel to store and deliver bursts of power to the ground. It also means you can modulate a much more aggressive power delivery, because when you need to reduce power you can just slip the clutch a bit.
There are a few transmission / clutch motors out there, but none with the flywheel mass I want or the power level I want, so here we are.
With 2.5kw of battery, I should be able to do about 20 miles with this at ~50mph, which is fine for our hard enduro days where we'll rarely see those speeds. There's space for plenty more battery. Weight should be equivalent to stock, but much lower CoG.
I've also got an 890 Adventure I want to design a new rally tower for, an aircooled ducati superbike build, the second endurance minimoto bike me and my buddy work together on, a bunch of flashing and ECU tuning stuff in the pipeline...no shortage of fun things to play with.
