ST Guy
Well-known member
12.8 for a brand new battery. A good used battery can be lower, like down to 12.6, and still be a good battery. (Assuming everything else is OK as voltage is NOT the only indicator of battery health.)
If a battery won't hold 12.6 or better, I start to worry about it.
And lithium ion batteries have different specs than lead acid batteries. And frankly, I'm surprised they even work on systems designed to charge lead acid batteries. If fact, I don't understand the manufacturer's admonition to not use a regular battery charger on one, yet that's pretty much exact what you're doing when you run your bike. On one hand they say don't use a charger designed for lead acid batteries. And on the other they say using it in a machine with a charging system designed for lead acid batteries is just fine.
