DIY
Here are the culprits I would check in no particular order, steering head bearings, bad tire, tire pressures, tires that provoke that steering behavior, suspension set up, worn out suspension, tweaked front end that binds up, loose steering stem nu, bent rim, and a bent frame. If it were me I would try to straighten the front end (loosen all the bolt except the top fork bolts and push the forks through their stroke then torque everything down again) and then see what happens. Honda ST 1100s use to do this as a result of their steering geometry when you took your hands off of the handlebars but I don't know about FJRs though. Also, Lou suggested a steering damper. I think that may be a mistake. A steering damper should be added to a properly functioning/steering motorcycle. It shouldn't be used as a band-aid for a system on the bike that doesn't function correctly. That can quickly descend into "hillbilly/ghetto" engineering.
So many Yes's
