701 sm
mine is noisy as hell. sounds like a tractor..runs good though as long as there is fuel in the tank. I'm due for a valve check soon as well..anything i should look for?
Thisll be the first so i donno. Called dealer, said $250 plus parts and 2 weeks out. Wondering if this is my best bet if I'm thinking there will be a warranty issue. Hate to tear into this thing and find and issue and bolt it back together just to take it to the dealer. 2 weeks is kinda long tho...
so put a little video together. Someone already has an in depth 701 valve check video, i just put this together to add a couple tips that i feel like would have been helpful for me to know right out the gate. Also took a couple pictures how to get the feeler gauge on the hardest valve to check (since that plastic piece gets in the way) and how the marks should line up so you know you're at top dead center (TDC). Hope it helps you out.
On another note, what do you guys think about the decompression system? Too much play? Anyone know the spec for the bolts with the springs on them?
[YOUTUBE]kEJ5Hv45tqM[/YOUTUBE]
how loud is your guys valve train? feel like my motors gonna blow up again. Not down on power, just noisy as hell.
A lot of the noise comes from the cam chain being loose at idle (Hydraulic cam chain adjuster).
I put an after-market, manual cam chain adjuster in mine, and it quieted-down a lot !
Sweet video!!
Do you know what the spec range is for the valves? I just checked the manual and it only gives 1 number , not a range that is acceptable
Sweet video!!
should be a grey sticker on your frame right by the valve cover on the left hand side of your bike that has the spec range on it. If yours does not I can take a picture of it later, lmk. You can see the sticker right at the beginning of my video, .10mm-.15mm for the intake and .20mm-.25mm for the exhaust.
what year 701 do you have? old 690 motor or new one? are they interchangeable as far as the cam chain adjuster?
SWEET!
thank you!
maybe after owning many LC4s, i'm immune to the noise. Here's what my 2019 SMCR sounds like bone stock.
I did a hot shutdown and hot re-start, this usually will cause the OEM CCT to click for a few seconds, but it doesn't.
[youtube]19iDNJqOsnk[/youtube]
I don't care how it sounds, as long as it runs good. I am in love with the quick shifter btw. If the 2020 701 gets that, I'm getting that bike for sure. :)
I thought the same, til i had an engine failure. It never sounded "different" to me, just loud valve train noise. If it were quieter it's very likely i still wouldn't have heard anything considering what the failure was. I guess having one fail has left me with some ptsd and I'm just not comfortable with the "i dont care what it sounds like as long as it runs good" mantra anymore.
How different is the 701 motor compared to the svartpilen? I'm in the market for another bike, miss the supermoto life but I want to do more street miles.
Yup, sounds like a tractor. Looks like and sounds like an orange 701 that went on a diet to fit into some skinny jeans.
That quickshifter is the part I want the most. I have kinda looked at retrofitting it but have found no info. The dealer wasn’t any help either
I would feel the same! As you know i've gone through my fair share of bikes and failures, and the PTSD post major motor repair usually goes away after I put some miles on the bike.
Same motor. This may sound strange, but I would much rather do highway miles on the SM than the pilen bikes. The stock gearing is tall. I don't shift to 6th til about 80 mph, and I am much more comfortable riding upright.
You can go aftermarket for QS, but only for upshifts
http://www.accessoryinternational.com/product/healtech-iqse-husqsh-p2b-quick-shifter-easy.html
If the 701 comes out with the same electronics package as my 690 SMCR, i'll get one and you can buy my old 690. I promise it will be the cleanest bike you've ever seen! :)
One huge upgrade on the 690 over the current 701 is the apex suspension. It's far superior! The valving is really good, and sprung very well.
I’ve been looking at that healtech qs. Do I want it, sure...do I NEED it? No... it is kind of nice having a bike with no electronics. When my new bike shows up, it will be fully loaded with auto blip and tft dash and carbon wheels :cool so having 2 vastly different bikes will be nice
I’m actually not having any issues with the suspension. I have lost 110 lbs since I bought the bike so @ 170, I think I’m in the target weight range for the current setup. Putting it in the sport setttings helped a lot as well
The stock suspension on the 701 is very good. They just improved it on the 690.
I did not want electronics on my bikes until I had it all on my 1290 Super Adventure R. It was amazing. Wack the throttle wide open in mid corner and the bike does a controlled slide for you. You don't even feel it or does it upset the chassis. Of course the 690 doesn't have close to the power of the 1290, but its still fun to play around with it. The Quickshifter is so much fun, it just fires off upshifts and auto blips for downshifts. The only thing strange that I never got used to is grabbing a handful of front brake while leaned over. But I guess it's good to know I have that 'safety' feature.
at first i was like, how tf did you get the bike down to 170 :laughing
Have any of you ran into this? 2018 701. About 4K miles.
It sat for a couple months while I drive my truck to work. Battery never died and it fired up right away. I’ve been riding it for the last week. No issues with riding. But...the display resets every time I turn the bike off. Even if it’s for just a second. Clock and trip meter.
Is there a setting that I somehow messed with? Any other ideas?
I have a 2017 (the manual chain adjuster is the same for the 16-17, even though the motor changed to a two-counter balanced motor) The 2018 and up had a revised (auto) cam chain adjuster, the adjuster is at an angle now, and thread pitch is different.
So if you are in the market for a manual cam chain adjuster, make sure to order the correct one.....
I will probably buy a 690 this Spring. Maybe a 2020 version.
What kind of OTD price am I looking at? I assume about $13,500.
Also, what kind of mileage are you seeing out of a topped off tank?
