Thanks for the help in advance guys...
So I just picked up a 96' XR100. Got the bike home, and was having issue with the bike bogging out when you'd open the throttle. Especially if you whacked it open it would almost die. It eventually started running fine and had some kicks for an hour or so before it acted up again. This is when I figured it was the carburetor.
When I had it up on the stand I checked the oil, and it was filled a little high, and pulled the plug and the threads were wet with oil it looked like. Put a new plug in, drained the oil and put freshy in at the correct level. Still died out.
So I just took the tank off, drained that. Took the petcock off, a little gunk but nothing crazy. Took the float bowl off? And there was a good amount of gunk at the bottom of that mini pan. After I cleaned dumped it, it looked like there was aluminum oxides in it?? Was weird (never opened up a carburetor before). Pulled all the little parts out that i was comfortable cleaning and putting back the way they were. Carb sprayed the shit out of everything in there. Seems to be cleaner, but the gaskets look a little worn and maybe some of those needles or jets could be replaced?
Where can I find the explanations of the screws on that carb? I looked all over and dont have a manual yet to refer to. I've checked thumper forums and anything that looked like a diagram or something would be posted...nothing...
Now this brings me to another question...A rebuild kit is around 35 bucks. I've found a brand new carb for 23! My first assumption is since its on fleabay its garbage....or is it??
And when I put fresh gas in (havent yet)...If I put 91 in it, would I have to adjust the carb depending on the pump gas I put in it?
Heres the link - http://www.ebay.com/itm/380467466702?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
What you guys think is the best route?
