any tips/tricks? front brake bleed on abs ktm duke 250
GPzPop
Ask me about my B-1-D
L i b m o
Blue, all three of them are blue
Simon
BARF perks
AMA #3295113
google say just bleed caliper and mc like a non abs,
tried, using vacuum bleeder, but lever still soft.
strap to tie brake lever pulled in and leaving it overnight did not being joy
any hidden technique ?
Was this just a routine bleed? Was the system full and working OK before you started? Or was the system dry, like a new brake hose or?
How soft is the lever now...are you building any pressure at all?
Sometimes a big bubble can get get stuck at the top banjo bolt...pumping the lever, and cracking loose that upper banjo can burp a big bubble and help things along.
This cut away shows why the zipped tied lever trick failed to past air to the reservoir... whereas lever released allows a clear path back to the reservoir...
Try the reverse brake bleed technique...
I am repairing crash damage (not crashed by me) where upon uprighting the bike, lever went to bar (amongst other issues)
lever is still soft after my attempt at vacuum bleed
I will look to do a burp of the mc banjo bolt
thanks for the guidance
- - S
Maybe push the pistons back into their bore as well in case any air got trapped in there somehow. Reserve bleed should work too, though I have much to my shame, never managed to get it to work on any of my attempts. Also if you master has a bleed port don't forget that. On my Ducati which does have ABS I just bleed from the caliper furthest from the master first, then the other caliper, then the master. Also, sounds kinda silly, but I've had success on the DRZ getting a firm lever while bleeding in a parking lot by firing up the motor and riding around the lot giving the brakes a workout, I suspect the vibes from the motor along with squeezing and releasing the lever got the remaining trapped air to work it's way up into the reservoir. The internets were suggesting the banjo bolt trick on the DRZ too, but in my case the parking lot trick worked :laughing
