Battery powered heated gloves
R3DS!X
Whatever that means
Daly Shity
Energica EVA
Honda 919
KTM 790 ADV
Royal Enfield INT 650
BARF perks
CRC MotoGP Contributor
Looking to get some heat in my hands. I have to touch people for a living and they don't like my icicle fingers after my commute. I try to heat my hands back up with warm water but it doesn't seem to last.
Who has em? Who has a pair they like? How much, what do they taste like? How long have you two been together? What did you father say? I have so many questions.
I need a set too. It just seems easier than adding heated grips. My fingers are the first thing to get cold when I'm riding while the temperature is in the 30's.
I can usually warm them up a bit by holding onto the muffler for a minute or two before frostbite sets in.
====== Edit ======
Looks like the answer is already waiting for us in this thread: http://www.bayarearidersforum.com/forums/showthread.php?t=531818
I commute on my Zero so I no longer have that luxury:laughing. I Want the battery powered ones so I don't have to install headed grips on everything and also I have then have warm gloves when hiking or whatever.
I have the tour master leather heated gloves. My commute is short but they definitely help. I think the model is the 7.4v synergy. When it gets real cold(or what we in the bay consider cold) I double up with them and elephant ears and have to turn them to low or off. Even not on they are comfy and fairly warm
I purchased the Tourmaster Synergy 2.0 Leather Gloves in mid October for my ~1 hour commute in the Baltimore area. My bike has clip-ons and no hand wind protection. I paid $208. I think they'd be perfect on their own for a Bay Area commute, but in MD I am planning to add heated grips eventually and probably upgrade to a full wired suit for the coldest days.
For the most part I have been happy with them. The build quality/protection seem excellent for winter/touring gloves and they are thinner than my Rukka lobster mitts but still relatively warm even without the heat on.
Above 40 degrees my hands feel noticeably heated and I find myself varying or even turning off the heat.
30-40 degrees my hands do feel a little cold but the cold doesn't stay with me after I go inside the way it used to and my hands aren't numb or in pain.
The lowest I've gone is ~18 degrees. Getting off the bike after over an hour at this temperature my hands did hurt, but the gloves prevented any numbness that would have been a more serious safety issue.
I charge them once a day at work and haven't wanted to test them and risk being cold.
On my last bike when I lived in the Bay Area I had a combo of Oxford heated grips + Oxford mitts. The mitts won't work on my clip-ons but they were great especially in the rain.
This won't help you but I'd thought that I'd share one of my DIY Winter projects. I am working on ducting some air with a fan from the front or rear exhaust header to my hand guards. I'm not even at rev1 yet but I've been scoping out ideas all week. I'll probably finish in June when I won't need it, lol, but it should be a fun project.
I had heated grips on my previous 'Strom and I didn't like how they felt. My hands cooked on the inside and froze on the outside which is better than the nothing I have now on my new bike but I am looking for something better. Besides, as an engineer it seems like such a waste to convert amps to heat when the whole motor is nothing if not hot. Also, I'd rather save my amps for lights or other doodads not heat.
I have Fly Racing battery heated gloves and they kept failing, so I removed the battery and there are decent non-heated gloves.
The heated grips weren't the problem. The problem was you were depending on them in conditions too cold for them alone.
There are many things you can do to keep the back of your hands warmer while the grips heat the front part.
Heated grips feel great, they just aren't an entire solution for really cold condition.
“I have to touch people for a living and they don't like my icicle ingers after my commute.“
I have one question, outcall only?:)
You're not an electrical engineer I take it? As a PE (Electrical), my advice to you is use the heated grips. :twofinger
Add in heated gloves, or bar muffs, or two-compartment Held gloves (that get your palm closer to the grip, and give you more stuff covering the back of the hand), or whatever it takes to be comfortable in the conditions you ride in.
Never been a fan of heated gloves. Way too much bulk, and that's coming from a guy that loves Helimot gloves.
I'll second the suggestion of hand guards of some sort to provide for a wind barrier, and heated grips to provide for some more warmth.
It's also key to understand that you NEED to keep your core warm. When the core temperature drops, blood flow to your outer limbs is reduced in order to help keep the core warmer. As a result, your hands/feet get cold. Heated vest will work wonders to keep hot blood flowing to your hands.
If I could only have one or the other, I'd take the heated vest, and throw on some sort of hand guards. Ideally, you get to have all three. With that set up and a jacket/pants/suit (Aerostich comes to mind), you can ride for hours and hours in freezing temperatures and be completely comfortable.
If heated garments are not in your budget, you can actually DIY a heated vest for about $30. I made one about 6 years ago, and it's still perfectly fine. There's a big ass thread about the subject over at ADVRider.
Why try to run air up there when you could run some tubes with coolant. More efficient at transferring heat than air. :nerd
Do any of you know if the Oxford ones will fit over OEM DL650 plastic hand guards? They don't look as big as the other brands??
Thanks
My older Oxford ones will. I haven't done so but I've fitted them over other hand guards. What's bad is using them with no handguard or support structure at all, as they'll press the levers at speed.
I tried to sell mine cheap on BARF a few years ago, but got no interest at all. Decided to keep them as a backup. I might get a smaller set of muffs (the kind where you can still see your hands) instead. Or try to fabricate something.
Do I smell a new client!?
I have heated grips and Hippo Hands on my DL650 with Barkbuster guards. I wear mesh summer gloves all winter with this set up. I commute and see 35F very often. My hands stay toasty warm.
