Abacinator
Unholy Blasphemies
You start by wrapping the rope around your hand three times.
Same knot?
Yes, it is.![]()
Just googled how to tie that one. It's a great knot, and I bet it will come in handy!
Same knot?
Yes, it is.![]()
Darn, that's the only cool one I know.![]()
All I know is how to securely tie a baby on my back (or front) with a piece of cloth.
Just lots of hiking.Re: tree sway, 2 questions come to mind looking at this pic:
Is there enough room for movement in the plane of the stairs (if the tree sways in to the stairs specifically). The top of the steps looks almost touching the platform.
Also, do you think there's enough slack in the bridge and handrails if the trees sway in opposite directions?
Pretty thick trees and not too terribly high up, so they probably won't sway that much I guess.
The staircase makes going up the tree house way too easy
That's marriage material right there bro!!Bad picture of me cause I was wearing my baggy jeans, but it shows the baby wrap pretty well.
The direction you mentioned specifically -- the tree swaying towards the stairs -- is my biggest concern too. It not only has limited movement, but is the most rigid, if the two surfaces were to collide. In the other direction there is more clearance and side to side, the stair can flex. This may be mitigated by the fact that we seldom get wind directly out of the north or south, which is the axis the tree would have to sway on to make head on contact with the stairs.
Pretty thick trees and not too terribly high up, so they probably won't sway that much I guess.[/QUOTE It's the thick smaller tree's, and general "ladder fuel", that scares me. Not knowing all the factors, but lightning started fires, are no joke, in places that look like that.
