I'm thinking of buying 2007 ducati monster 695, and i was doing some research and came across black keys, red keys and code card.
from what i understand, you need the red key to program any new black keys, and the code card is for when some reason your programmed black key isn't working and you DONT have your red key at the time, so you will have to play with the throttle in order to start it up again.
so without a red key, i'm pretty much screwed at getting any copies and if i lose my only black keys, i'll have to sell an arm or leg or maybe both to get a whole new dash
also, how likely is it for my black keys to randomly stop working, thus having to use the code card to start it back up?
Please correct me if im wrong at any point. i'm not familiar with Ducati and different keys.
anyways the seller does not have the red key or code card.
should i still proceed with this deal? what type of problems will i run into without the red key or code card?
and getting a new ECU and possibly not needing the redkey?
BARF
