Mazda's made a camless engine for like 40 years...
My question is - could you eliminate the starter motor?
Open or close particular valves, squirt some gas in and light it...
Yes I know, compression might be an issue. But it might work.
F1 has been using pneumonic valves for a long time to close valves in place of a valve spring. They react faster than springs therefore reduce valve float at high rpm.
The pneumatic valve springs on f1 engines are air chambers that are compressed as the cam lobe pushes down on the valve and the air pressure pulls the valve back up. But there is still a cam compressing the valves.
The design in the first post has no cams and uses air pressur to push the valves down and a spring to close them.
2 strokes![]()
Yes I know the camshaft is still there in F1 that why I said pneumatic to close valves.
those motors also get taken apart after every race, so long term reliability at the seals isn't really an issue.
