catch2otwo
Active member
Bike in question 2001 gsxr600
Was told bike has a bad top end.
Checked valve clearances - all in spec
Didnt have a good battery. Cranked it over by hand with a compression tester and got 75, 105,120, 90psi. I know you are supposed to do it warmed up with a good battery. Just wondering if hand cranking it, how close would you get to spec if everything was good.
Just seeing if i should invest more time into this or if those numbers are a tell tale sign of internal issues
