Sharky
Well-known member
So, I go to start my G1K this morning. Turn the key on, fuel pump spools up and the lights come on. Hit the starter button and everything goes black. No power, no nuthin'. Work the key a couple of times with zero results.
Took the seat off and check the voltage. 12.73v key off. Turn the key on and the battery drops to .003! Looks like it holds absolutely zero load, despite having a full charge. I have a spare battery floating around which I will try this evening (took my KTM to work instead).
Any other ideas besides a seriously screwed battery? I didn't do a fuse check because I didn't have time to waste this morning and the fact that the by turning on the key dumps the voltage leads me to believe the fuse connections are working.
