Douchebag at trackday
A few observations after a few hundred trackdays. Pass for the comfort of the other rider. Inside passes are fine if you pass before the other rider turns in. If you are getting passed on the inside, consider giving more room on the outside. Most will take the outside pass if it is there.
T8 passes create too much risk - many people miss-time them causing stolen apex’s and with the high speed a sudden reaction to someone taking your line can have you pointing off the track. If that happens, try to keep turning until you run out of pavement and keep your weight to the rear like a dirt biker.
Riding out off track T8 nearly parallel is far less likely to crash than if you go straight off. What people don’t know is in spring when cars go off, they leave ruts that dry out and can cause a MC to crash almost certainly.
One last thing- I have been told that certain T-day providers generally attract more mature riders than others. But there are always a few that cause problems - most often not intentionally.
I think the culvert I found off T8 is still there...about halfway up to T9. You can't see it till it arrives and the best you'll get out is "oh Fu.....". Then you get kicked off like a bullride.
