Driving Light recommendations?
Thanks for the post-is the draw OK or do you notice a dimming of heaslamp when they turn on?
I've been meaning to take some night shots - need to get that Piaa switch installed so I can do a comparison with the lights on and off.
I can detect no dimming of my headlight or dash lights when the Hella's kick in. Both the Hella's and my headlight are powered direct off the battery through heavier gauge wire kits with relays so don't add any stress to the stock wiring harness.
Do you have some kind of ignitor or other type set up so it's not always ready to turn on, even with the ignition off?
I believe the relay has the ignition on wire, not this switch
The relay is energized by a tap wire coming off the hi-beam. I'll wire the Piaa switch to interrupt that tap wire to allow full control over the Hellas.
