Burning1
I'm scareoused!
stav2201: do not stat the bike again until you diagnose the oil pressure warning. Yes, with that warning on it is possible that you damaged an oil passage, oil line, the oil pickup, or the oil pump it's self.
How much are are we talking about here? Air does compress, but the coolant pressures already rise high enough during normal operation that the radiator cap lets off excess pressure by venting fluid into the coolant reservoir.
I'm not suggesting that air bubbles won't result in higher engine temperatures, or that they will reduce the boiling point. What I'm suggesting is that unless a very significant volume of coolant is displaced, it shouldn't* cause an increase in the indicated coolant temperature on the dash.
Coolant temperature is entirely dictated by the engine's ability to put heat into the coolant, vs the Radiator's ability to get the heat out. Coolant temperature will rise either through an increase in heat production, or a reduction in heat elimination.
Conversely, if the engine is not able to transfer heat into the coolant, the coolant temperature will drop relative to a healthy engine, even as the oil temperature and internal component temperatures rise.
* Although I could imagine a situation where there is a localized hot-spot next to the coolant thermometer.
* Also, If you displace 5% of your total coolant with air, the remaining coolant would have to get slightly (about 5%?) hotter in order remove the same amount of heat from the engine.
Actually, it would cause overheating and here's why:
A pocket of air can easily be compressed by the expanding coolant as the coolant heats up. As a result, the required pressure never builds up in the cooling system and the coolant then can boil at a much lower temperature. Once the coolant starts to boil, it's effectiveness is greatly reduced and things start to get even hotter. End result is overheating.
