I can't remember when I last used red loctite. The blue has always worked for me.
Yep, me to.
One (un-named Mfg) has mounds of that red crap in some areas. You have to torch the fastener out, then torch and chase (tap clean) all the threads. It's a major pita. Even the replacement bolts are covered on the threads. I still get mad thinking about it.![]()
My general experience has been that small fasteners with red tend to turn into major PITA's.
Those are metric hex caps, 5mm if I recall. I used a short 5mm attached to my snap on cordless impact and they came right out. If you are having trouble, just disconnect the wire harness attached where the stator plugs into your rr or harness and come down to my shop with your new stator as we'll and I'll show you how and also how to put back together correctly.
No prob. It's not mine, but we follow the same guidelines to chase down gremlins. I've always found that with simple concise electrical testing, order and patching point A to B, you can get things fixed a lot faster.
Entropic: Postscript to my last;
There may be thread locker on those bolts, not sure if yours has them or not. I have seen it on some bikes, but not always. Shop manual for your bike would spec that. The bolts are generally around 10-14Nm (90-120inlbs -ish), again, depending on the bike. If you don't have an accurate torque wrench, borrow one. Again, follow Mfg. spec and guidelines. Sometimes where heat/cooling is a constant, threadlocker could be used as a safety net to prevent loose bolts from backing out completely and spinning around areas of your motor assembly, like the rotor/stator area. I am NOT recommending or denying you should use it. Read what the Mfg states in the manual.
Mild Rant Warning:
A side note about Threadlocking compounds mentioned above. On a couple of our bikes, the Mfg goes nutty with that stuff sometimes. I have seen it covering entire threads, which isn't needed or correct. The purpose of threadlocker is to add a vibration retardant to the bolts backing out should they loose tension on the joint. It is NOT a glue, it does NOT replace proper Torque of fasteners, it should NOT be your only method of securing fasteners properly.
We use very very little of it, if even at all. Sometimes a tiny drop or two on a stud to reduce mobility of the stud threads backing out, but again, very little. In most cases, we use a medium bond (blue) when we do, almost never high bond (red).
Now I said all this because many times folks will use Red Locktite up the ass on bolts, screws and studs. It's really unnecessary, and again, if the fastener is applied and torqued correctly, you are generally fine. Some caveats exist where threadlocker may be advantageous, but those instances are clearly spelled out in shop manuals most of the time, or understood in adbvance.
/Rant Off.
Yep, me to.![]()
Depends on bike/yr/motor/etc. But there may be a little bit. Put a small pan under it when you remove the cover. It may have a heavy magnet pull, but DO NOT PRY IT OFF(hope that was clear enough).
Anywho, don't let what oil is in there spook you.
---> BUT, a better way to approach this may be to warm the bike up a bit, drain all the oil (like you said above), change the filter, fix your stator, put the cover back on, refill with freshy oil. You get a service out of it, and less oil coming out of the cover. Win-Win.
all of a DR350s oil comes out when you pull off the stator cover.
If you lean the Dr over about 15-20 degrees to the right you can change the stator without all the oil spilling out.
