ST Guy
Well-known member
The proper way to bed brake pads in is multiple hard stops from speed to near zero (no stopping allowed), and then some time for some cool down. And I mean really getting them hot so you can smell them. Of course, this is easy in a car. Most people aren't going to try that on a bike because of the risk of crashing.
And all pads, regardless of compound, work the same way. A small layer of the pad material is deposited on the rotor and it's the friction between the pad and this thin layer that does most of the work. Change pad material or material formulation and what has been deposited on the rotor from the previous pads may not work well with the new pads. That's the main reason for sticking with the same pads and not switching all the time.
Unless there's a problem with your current master cylinder, don't change it. It was designed to work with your calipers. And I doubt you have a warpage problem. Just clean them to get the old pad material off them. Or replace.
Here's some great info. It's car based but the theories apply to all brake systems.
http://www.stoptech.com/technical-support/technical-white-papers/-warped-brake-disc-and-other-myths
http://www.stoptech.com/technical-s...pers/bed-in-theory-definitions-and-procedures
