I want to program my Trailtech lights to indicate when to shift.
5467.904 rpm, on warm days 5428.258
Remember to adjust by .0325798 RPM per .000025687 difference in average pug gap (averaging across all 4 cylinders, but weighting the inside two cylinders 2.48% higher in calculating the average).
Asshats!!!Not true. It's an upright bike, and while the Trailtech Vapor tach is hard to read without giving it too much of my attention, the shift lights are easy to see while riding.If your eyes and attention are where they're supposed to be, the only time you would even really be able to pick it up visually would be in more of a tuck position.
so if you find youself always shifting at 4000rpm that means you need only 25hp in your everyday life. Which I think is the case. In that case you really should've bought a 250 Ninja, b/c it also makes 25hp.![]()
bruum bruum... bruuuuuuuummmmmmmmm....This man knows many buzzwords. This means he is smart. Listen to him.I was using the LaPlace Vernier formula weighting and integrating the differential across the entire range of output, leavin out of course, the minimal mechanical distortion due to retrograde buffering.
What the hell is a 'shift light?'
I find I barely can get into 4th gear in the city. I use 2-3 mostly. I just don't need that speed for puttering around SF.
YOu guys are messed up !
PLUS: you didn't include the "stiffy factor"> bulge in pants automatically adds 1K rpm to shift point
Asshats!!!
Just stick with doing it by feel. Forget shift lights. Who needs one for the street anyway? If your eyes and attention are where they're supposed to be, the only time you would even really be able to pick it up visually would be in more of a tuck position. And you won't be doing much of that on the street.
one must also include the natural variation in earth associated constants such as the pull of gravity, the coriolis effect, and any atmospheric humidity variations as one moves through various zip codes and their impact on tangential oil spray velocity in the crank case.
"Shift lights" are things that are known to people who drive or ride, instead of doing saber rattling on online forums.![]()
one must also include the natural variation in earth associated constants such as the pull of gravity, the coriolis effect, and any atmospheric humidity variations as one moves through various zip codes and their impact on tangential oil spray velocity in the crank case. presence or absence of strong electromagnetic sun-earth interactions as well as the position of the moon relative to one's current location also play a significant role. to ignore any of these factors is almost as dangerous as running car oil in your motorcycle or putting the wrong color air in your tires.
Does BMW make a tool for that?
post reported for name calling, enjoy your spepension
beleive it or not, it's actually a Yugo derived spec, and the adjustment tool is made from Unobtanium with gold, plutonium, and helimum as alloying elements
Doh!!!
Stupid thing is left-handed though![]()
