cuz my feelers on my pegs scrape at about 65 degrees (they were not scraping)
and I know 45 degrees is 1/2 way to the ground (which I was a little past)
so I am guessing about 55 degrees.
Maximum lean on a MotoGP bike on a dry track is about 65 degrees. I repeat: MotoGP. Dry. Track. Prototype 16/16.5 Slicks. Properly heated. 65 degrees. Maximum. Would you like to revise your statement now?
edit: to add to that, while it's an oversimplification to state a maximum possible angle on a tire without considering rider body position, tire width, and road surface, even Michelin says (proudly) that the Pilot Powers can handle "up to 51deg" of lean.
I had 2 friends lean the bike over towards them while I stood back to see how
far it would need to lean 'til the scrapers touched the ground.
It was at about a 65 degree angle when the scraper touched...
However, now thinking about it in retrospect, I did not think about the
bike not having a rider on it, compressing the suspesion bringing the bike
lower to the ground
+1 (but change "centripetal" to "centrifugal" as it is the force pushing the rider and bike down (i.e. compressing the suspension).
just to bring up an alternative, i love my pilot road 2 tires on my XB. im way faster on my XB than my 1125CR which has corsa IIIs. I know this because, i had a couple of friends tell me so. I had the bikes up on stands and i sat on the bike and tucked and they said that i looked way faster and more comfy on the XB than i did on the CR.
also, while the bikes were on the stands... we threw rocks on the PR2s and the corsa IIIs and more rocks stuck on the PR2 tires than the latter. this means the PR2s have more grip.
lastly, we spun the front tires like a wheel of fortune then we stopped it with our hands, we measured the how long it took for the tires to stop spinning and found that the PR2s stopped faster, which shows better stopping power than the corsa IIIs.
i believe that with these tests, i have scientifically and empirically proved that the PR2s are a better tire than the corsa IIIS
if someone would loan me an anget st tire, i can test them against the PR2s and we can see which is the better tire.
we dont even need to mount them to a bike as the my roll-the-tires-downhill test will show a clear and definitive winner as to which is the faster tire.
I don't have the same bike, this is my 3rd aprilia RSV, I purchased this is September after someone hit me on 680. And I have dealer plates cuz I never got a license plate. Until I am cited for It I will continue to have it.
and of the perks: free bridge toll, If I don't trigger a light I am not phased by red light cams etc etc.I have 6,4** miles on my current RSV, it came with Pirelli Dragon Supercorsa Pro's and I bought it with 000 miles from Vespa of Long Beach in LA.
And since I just changed the rear tire what does that mean?
It means that however many miles are on the ODO is how many were on my tire.
MilleRacer69,
Based on your quote above, I'd suggest you get that plate on now if isnt already. I'll be looking for that bike now![]()
MilleRacer69,
Since it is intentional, and you are aware of it, is he looking at a fix it ticket if you catch him, or something more?
Mille, I would take his advise and put it back on...
