channelcat
swingarm sticker? hmm.. nope no swingarm. hard to imagine a VIN on a removable part. You might be thinking of the gear ratios stamped on the rear drive housing. /7s had the tall 32/11 ratio, coupled with around 57 ft.lbs torque and a heavy flywheel=oompa loompa. now if you could just get the thing to spin 9k...smooths out at 3k, right there 4k to 6k, mine pulls to 7.5k redline...lightened conrods, cut the piston skirts, balance everything to a wet red one, 34mm flat sides
if you ever run into Billy Peck, hes probably done it as sane as it can be done. so that leaves
