TheRobSJ
May lose 10mm sockets if distracted
So we have two fuel additives from them, the 44K and and another one that is considered "premium" and comes bundled with the MOA oil additive which is called CF5. 44K and CF5 are exactly the same stuff, but whatevs. 44K can also come bundled with the air induction system cleaner....now that shit I would never use on a car from anyone I gave a shit about.
44K or CF5 is probably pretty harmless. Probably comparable to Techron. Or maybe not, but at least it probably won't hurt anything.
Transmission additives on the other hand.... While I said that my shop uses damn near everything from BG, the transmission flush/additive is one thing we don't. I considered it a personal victory that I was able to keep that out of our menu. It took a lot of convincing to do it too, since all that BG stuff sure does make the P&L sheet look great to the boss. Maybe not so much with other brands, but with Honda/Acura it's best to use the exact recommended fluid and not to do any flushes of any kind. So many times, I've seen someone come in with the complaint of some intermittent wierd shift/slip, and get figure that a flush will cure it. Nope. All it does is all that new clean ATF (which has much more detergent additives than regular motor oil) circulates, breaks loose some gunk inside which promptly gets stuck in some shift solenoid somewhere. Then it blocks a shift or the computer can't regulate line pressure properly and then in a matter of weeks or even days, the car is coming back to the shop on the hook with a totally screwed transmission.
