Pulling the upper and lower injector connectors, plug them into dummy injectors. Should be no other changes.
if they were running water wetter it could turn milky if they used too much of it but the fact that you have tight shims and milky coolant points to overheating / blown head gasket
i wonder if this could be caused from disabling one of the cylinders? if done incorrectly? how was the bike crippled?
Milky coolant could be bad water pump seals. But usually that results in a leak by the "tell-tale drip hole". I think in some rare cases that hole can be blocked and allow the fluids to mix instead of leaking out. Long shot only. How does your oil look?
Now I feel lucky that my somewhat inexpensive R6->4.5 only took me suspension refresh for my weight, $50 in e-bay injectors and harness, and a rather annoying but uneventful valve job after it enjoyed stalling and not running cold during its first track weekend.
