Still, having a fiber optic conduit from a rear lens into a front projector is advantageous because it takes much less space. This mirror system, while compact, still takes a lot of space - space that could be used for impact absorbing EPS foam.
Imagine having a smallish lens in the back of the helmet that feeds a fiber optic taper running to the front of the helmet. It achieves the same effect, but is much more compact.
ok, i admit i don't know much about fiber optics but i googled "fiber optic taper" and they're certainly cool
how do you do it without violating the minimum bend radius of the fiber?
they also seem to have an intrinsic quality of magnifying whatever you're viewing, or making them smaller if you turn the taper around. With magnification would come an increase in light intensity which would be bad, and the converse would be true as well if the taper were reversed....
i'm just curious, drop some knowledge yo!
i'm pretty sure the short answer as to why fiber optics weren't used, other than being technically challenging, is they're just too expensive.
