So if you believe Energy Conserving is bad, Resouce conserving is no better.
Thanks I saved your quotes...
I believe there nothing to fear about Mobil 1 EC or RC oils... because of all the
elements listed in the virgin samples not one is known to defeat our wet
clutches in good operating order... if your clutch is loosing its grip check for
high mileage and normal contaminants...
There is a time tested way to save $$$$$$ in new clutch parts by investing
in some sweat equity... deglazing clutch plates ain't nothing new... no sir...
back in the 70s it use to be part of every savvy rider's maintenance plan...
and for some reason that all change during the 90s... why fix what you can
buy new is the what you hear now a days... but if your interested in making
your clutch bite good as new then roll up your sleeves and read on...
Inspect the friction plates for glazing... make sure you have plenty
of material to work with...
First removed the contaminants with something like Acetone... then lay
each plate over a 600 grit black dry emery paper and rotate in a
circle... you're just busting the glaze... don't get carried away
remove too much material... You should end up with a friction plate
looks dull like a new one as opposed to a shinny glazed one... recheck
thickness...
Next check the pressure plates for bluing caused by localized heat...
make sure they are not warped... check manual for a stated thickness
range... now removed the contaminants with something like Acetone
and wire wheeled them to erased the blue and also to generally scuff
up the surface... you should end up with a dull surface free of Blue
marks...
