bagged
i found the rebound on the front to be way to little at 8 clicks out(not sure if this is factory or not, bought the bike used) it feels MUCh better at 4 clicks out on front rebound. I am running 4 out front compression as well.
bagged said:i found the rebound on the front to be way to little at 8 clicks out(not sure if this is factory or not, bought the bike used) it feels MUCh better at 4 clicks out on front rebound. I am running 4 out front compression as well.
antarius said:So you felt like the front wasn't coming back quick enough at 8 clicks? Moving it to 4 doesn't cause it to feel bouncy?
I happen to prefer a lot softer of a ride, so I go light on compression -- but to each their own on that.
FrigginChi, What's the downside of raising the forks? High speed stability? What kind of riding do you do? I raised my tonight, to the bars, and from what I can tell its about a 12mm increase (or decrease actually, since its lowering the front).
Went around the block a bit and that, coupled with the 70mm race-sag, seemed to make it turn in a ton better. I'm just curious what the downside is.
Thanks!
there was not enough rebound damping for me. 4 clicks out is more rebound damping than 8 clicks. Sorry I wasnt clear on that in my original postantarius said:So you felt like the front wasn't coming back quick enough at 8 clicks? Moving it to 4 doesn't cause it to feel bouncy?
Thanks!
bagged said:there was not enough rebound damping for me. 4 clicks out is more rebound damping than 8 clicks. Sorry I wasnt clear on that in my original post
Lester Green said:Have you guys made sure that your fork springs are correct for your weight. I know in my case that is usually the firsat thing i have to do. usually a bike stock sprung for a 170 rider. (i'm over 200). unless you have the correct sring to begin with all the other settings are pretty mute.
