The 08-09 uses a different stator to the earlier model (which shares the same as the SV)
I'm less familiar with the VStroms - can only imagine they wound it differently to be able to utilize more accessories (speculative) - if so, the problem is this would produce more current at lower rpm however potentially becomes a problem at higher rpm. Stator design is a balance between trying to get enough current at idle without having it destroy itself at higher rpm. The stator cooling on the SV is excellent and have to believe the VStrom would be the same. So the only conceivable difference would be in the output power.
Makes no difference to the stator current whether you run more or less load on the bike itself - for example if you turn off the lights, the R/R will shunt additional current through the SCR's to attain regulation - however this does not
add current to the stator - merely moves it from the system load to the R/R. It will certainly make the R/R run hotter if you reduce the system load but will not change the stator load AT ALL. Think of it like a diverter valve - current is flowing out of the stator and gets switched either to the load or to the shunt - both paths return to the stator. If one leg goes up the other goes down.
So - if the system load goes down, it
can lead to R/R failure (as it will work harder, shunt higher current and get hotter) but will have no affect on the stator.
Here is some data from one of the GS guys who measured the stator current on his bike with Shunt vs Series
(reproduced from GS Forum -
http://www.thegsresources.com/_forum/showthread.php?t=209843)
Interpreting those results, shows that the stator design is producing just barely about enough current at idle to satisfy the load - that is why the current is the same with either type of R/R - in the series case is running pretty much wide open and in the shunt case is shunting very little. i.e. all of the generated current is going to the load. The output voltage is not quite at peak, so both R/R have output not quite satisfied by the stator.
As the rpm increase however, now both R/R types have to start working:
- in the case of the Shunt unit, the excess current is diverted back through the Shunt and the current goes up (note that the system load would not have changed however the stator current goes up dramatically!!)
- with the Series R/R, the stator current is virtually unchanged because instead of shunting back excess current, it operates differently by only allowing through enough to satisfy the load. It is drawing virtually exact same current from stator at 4K as it is at idle.
The final piece of data shows what happens when you turn off the lights (i.e. reduce the load) - the stator current goes down with the Series R/R. Not shown, but in the case of the Shunt R/R, this would make no difference, it would remain the same.
