I'd like to revive this thread. New developments have occurred. I've stated on BARF that I'm an "out of the closet telepath". But like most, I have little training or no training, but I actually have some training. I'm a republican conservative and libertarian. I'm totally into state rights. However I must point out that some one or some thing has gripped our Federal Government. The press points out about 30 top republicans "getting out" under Trump, but history points to a larger picture. Under Pres. Obama, the democrats lost 950 seats at the state and federal level and he fired about 200 top Generals over 8 years.
Something is happening. I'll pose this weird question..."do you feel like your life is weird or changed since about 2010?" There more to this question then most want to know...
Perhaps the "swamp" is real. Perhaps something more or different is real.
What we need is a candidate that takes on Trump at another level for 2020, which I suggest is telepathic. It appears all other attempts have failed. His twitter wont work at the telepathic level. It will require some one that can talk to thousands and not be seen on TV. It will be word of mouth. It will be a new new way to run...since Trumps new way fantastic victory...it was fantastic...
Now to riding. I'll reveal some more jedi stuff...
Telepathy is not you doing something, but rather you sensing your body. Your body is an antenna, and when you sense a reaction in your body (while riding) then slow, look, and cover your brake. It means something COULD be around the corner. Don't try to sense whats around the corner, just listen to your antenna or body. I've found it to be correct 40-50% of the time and totally turned off 10% of the time...which means I enter a blind corner and had no idea some was there. Wear gear, add armor especially where your elbows touch your ribs. Most manufacturers miss that armor placement...stupid...I ride "fly" by instrument. MIND YOU MOST TEACHERS DO NOT RECOMMEND THIS. I completely disagree with them. As I approach a known corner, I know the speed I should enter it at and then check my speedo and adjust as needed. It seems to have worked for 200k miles. Again, most do not recommend this but I do.
