netjustin
garden knome
When you're done waxing your spoke can you mail them 2 me?
I've developed a bunch but it all depends on what you're cleaning, and what's on it. For the engine, for example, I've used a combination of sand blaster, angle grinder (with wire brush), hand drill with various wire brush attachments, sand paper, Scotch Brite pads, Dremel with various attachments, wire brushes, brake parts cleaner, carb cleaner, Q-Tips, screwdrivers (for scraping off the thick buildup of road grime), sharp little dowels to get in tiny places, parts washer...and that's probably it. Oh, wait, and razor blades and a wood chisel for the ancient petrified gaskets.
For the rims I mostly used the wire brush on the angle grinder and the dremel, but I also treated them to 2 different rust removing chemicals.
The hubs I did with some fine grit sandpaper.
I used a lot of paint stripper, of course.
My best tool has got to be patience, though. I have spent dozens of hours removing rust and dirt at this point.
And lastly, you gotta know when to just chuck something if it's beyond saving.![]()
Next problem: this is my cam chain sprocket, it's practically toothless. A guy on another forum found a replacement 70's Kawasaki Z1 part that can replace it. Its steel. I'm going to order it on Monday. Another few bucks I don't want to spend but if the cam chain skips a tooth my engine will likely grenade. $80 worth of insurance seems like a good deal.
That is an offer to help Mr.Twitch. PM me when you can be over this way and we will get it done, and you can meet a guy that has lots of 160 tricks (from the sixties) you might be able to use with yours.
tifier. There was melted rubber all over it, and from my reading it seems that when selenium regulator/rectifiers go they get very hot. I'm on the fence about what to do with this guy, I'll have to think about it some.
Sorted out my cables. My rear brake line and my clutch line are good, but I need replacement cables for the throttle and front brake.
You don't need a rectifier if you run a total loss ignition system. Just a thought...![]()
I also found this strange bolt in my bad of front brake parts.
I can't get a good sense of scale from the photos, but that looks like a rear brake plate to brake stay bolt? If I remember correctly they are typically cut on one edge like that on Hondas to prevent spinning and loosening?
That's all I can suggest until I have time to look at our 160.
Cool. Any recommendations as far as Dremel attachments go?
