Yes.
Given your description of the event, I suspect that two things were happening here: 1) you weren't looking as far though the turn as you could / should have been, and 2) that you were attempting to (counter)steer by leaning on the handlebar rather than just pressing it forward.
I've been playing the scenario in my head for the past 3 days. I think your right, in going back and looking on Google Maps street view, I think I wasn't looking as far into the turn as I should've. I remember not seeing an exit, and got fearful when I was starting to go wide. At that point *I think* started looking at the railing. I seem to have more recall of the railing and the small hill below rather than the exit. LoL I'm not sure about leaning on the handlebar as opposed to pushing. This is something I'll definitely watch for in the future!
Rolling the throttle is what you do when you know you’re on the right line. If you’re not on the correct line, e.g. running wide, you shouldn’t be rolling on the throttle. Ideally, you want to wait until you know you’re on the right line before beginning to roll on, but if you find yourself in a situation where you’re rolling the throttle through a turn and running wide, you’ll have to give up some throttle so you can steer into the correct line. Adding throttle and lean at the same time is a no-no.
I think your right, once I was in the corner, I don't remember letting off the throttle and slowing down. At least not at first.
Don't be afraid to use the brake in a turn. Your tires have plenty of grip, and smooth application of front brake while adding lean angle isn't going to overpower them. I recommend that you practice doing that to gain confidence. Approaching a turn, on the brake, begin to lean (by pressing on the inside bar) AS you gradually release the brake. This is called "trail braking" (you're trailing off of the brake as you add lean angle) and some riders do it on every turn. I'm not one who does, but it's a valuable skill to have.
If I correctly understand what you experienced on Saturday, you could have kept the brake on as you leaned and delayed transition to the gas until you were comfortable with your line and speed for getting through safely.
A technique I really like for reading a curve before committing to line and speed is
The Vanishing Point (link is to my 2008 BARF thread). Basically, it uses a visual cue to recognize that you haven't yet reached the tightest spot of a blind curve, which tells you to continue to slow. Another cue tells you to get back on the gas when you're past the tightest spot. Read the thread and study the pictures, then try the technique next time you ride.
I'll read the thread and also do some searching on youtube for Trail braking & the Vanishing Point. Thank you!
I try to keep light throttle in turns, but headed downhill sometimes I can't do that and need to be using the brakes instead.
You didn't state how you resolved this issue. I always have an intended line through a turn and as soon as I'm even six inches wide of that line I start doing things to tighten it up. Sometimes that involves more lean angle and sometimes it means using the brakes to slow down more. Recognizing the issue early and correcting for it works much better than having to take drastic action after you're way off line.
So what road were you on when this happened? I used to live in Folsom, so I I've probably ridden every interesting road heading west out of Placerville.
I think I got spooked by the view and the railing and became fixated. Also, I was applying throttle and didn't consider that the decline would increase speed.
I was on 50 heading west, I think I was here:
https://goo.gl/maps/N2yGvZ3TUPLEn8kN8 It looks right. I recently moved out here so I was exploring. In looking back on Google streetview, I feel like an idiot given the grade and the angle. I should've been able to make that corner without a problem. I had no problems going east.
I got out of it, when I looked hard to the right and saw a line out of the corner. By that time I was pretty much through the corner although very close the line.
If this was on the freeway, I think you need to do a lot more practicing.
Your right! I just recently started going on the freeway. Before Saturday I was limiting myself to the area east of Elk Grove, Florin & Sacramento.
downhill + light acceleration == more acceleration. adding speed while not being comfortable with the line is your primary mistake.
this
doing this without addressing speed is misguided. adding lean angle while also adding speed is one of the riskiest things a rider can do. not adding speed is far safer than adding lean angle.
of course, this depends on the situation and some information we are missing. if the rider never attained a turning radius that would make the corner, more counter steering is absolutely necessary (or more brake before the turn). if the rider was on the correct turning radius and ruined it with acceleration, the safest fix is to not add that acceleration. I read the OP as the latter.
Your right, I failed to take into account that the hill would provide additional speed. Also, adding speed while increasing angle. I think I ruined it by keeping an open throttle and becoming distracted.
He doesn't say but I wonder if there wasn't some target fixation working on him in the curve. . .
I think you're right. In thinking about it and reviewing google, I believe I became fixated on the view and eventually the railing.
The above addresses two key things:
- Knowing the shape of the turn and where you are
- Being able to establish the right line
Looking into the turn before you steer lets you see the nature of the turn, ensure your speed is right and establish a target to steer towards. Countersteering sets the lean angle and line.
A nugget of gold here.
One of the benefits of rolling on the throttle is that it stabilizes the bike. A stable bike tends to hold its lean angle and line. If we begin the roll-on before lean and line are set, the bike will hold
that line (running wide).
Thinking back on it, do you think that at the time you rolled on the gas you already saw the shape of the turn and the line you were on, or were you a little unsure?
Initially, I saw the shape of the turn but became unsure as I moved.
Thank you All! It's really appreciated. You've definitely given me things to think about.
