Hi.
Recently, I experienced a problem with my bike. As I was riding, I felt it started loosing power in the lower range, and soon after it just died and refused to start back up. I had it towed home and when I tried to start it up a couple of days later, the bike started up without any issues.
Before taking it for test runs to see if dies again, I decided to do a couple of pieces of maintenance that were due (bike's at around 25000 miles). One of them is spark plugs. I bought new spark plugs and installed them as per the shop manual/youtube videos - I have magnetic spark plug socket to guide it in properly and once in place, I torqued them to spec with a torque wrench.
However, when I tried to start the bike, it just didn't. The starter is turning, but plugs don't seem to be firing. Did I miss some standard step in installing them? The only thing I can think of is that I didn't do anything to the gap between the electrodes on the plug, assuming it to be correct since the plug came straight from the box. Was this an incorrect assumption? What else can it be in your experience?
Thank you!
Luka
Thank you!
Luka
